What 1.6 rockers would you buy? #258050
03/18/09 12:54 PM
03/18/09 12:54 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
Hey Guys,
I am considering buying some 1.6 ratio rockers this summer for my street car. I am running the 509 cam but the comp version. It is a copy of the mopar cam but it has a little more duration on the exhaust side. This is mainly a street car but it will see occasional thrashing at the track when required.
My question is who's rockers are you using and is the swap worth the expense?
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: What 1.6 rockers would you buy? [Re: 451Guy] #258051
03/19/09 10:39 AM
03/19/09 10:39 AM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
No one runs 1.6 Rockers on a Big Block?
Thanx 451 Guy
Re: What 1.6 rockers would you buy? [Re: 451Guy] #258052
03/19/09 10:48 AM
03/19/09 10:48 AM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
I used to have 1.6 Harland-Sharp rockers. On the new bullet I have 1.6 T&D rockers.
Re: What 1.6 rockers would you buy? [Re: 451Guy] #258053
03/19/09 10:49 AM
03/19/09 10:49 AM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
I would try the Crane Gold 1.6 for something like that. Or the rockers from Hughes Engines. The Hughes would be my first choice.
Re: What 1.6 rockers would you buy? [Re: bobby66] #258054
03/19/09 10:53 AM
03/19/09 10:53 AM
Airville Pa.
boomer Offline
boomer  Offline
Airville Pa.
I wouldn't bother for a street car that would occasionally see the track. There will be no "seat of the pants" difference between 1.6 and 1.5 rockers and it probably will only help your E.T a tenth .
Re: What 1.6 rockers would you buy? [Re: boomer] #258055
03/20/09 02:27 AM
03/20/09 02:27 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I WOULD buy Erson rockers. The only problem is, that they don't make them any longer. The design and quality was great, and the price less than T&D's or Jesels, had they only advertised somewhere they would have been popular enough to continue the production.
Plynouth VIP '67 TT IC EFI
Re: What 1.6 rockers would you buy? [Re: bobby66] #258056
03/20/09 03:58 AM
03/20/09 03:58 AM
Macomb Michigan
65 Belv A990 Offline
Macomb Michigan
IMO with anything over 200-225 Lbs on the seat, I would stay as far away from the Crane Golds as I could. That is unless you are looking for a $340 set of one season throwaways. I agree in a street car there will be little to no seat in the pant's difference between a 1.5 or 1.6 ratio rockers. T&D’s and Jesels are the stoutest but a waste of BIG dollars in your application. Harland Sharps have always been good to me but for extreme street duty and close to the same price, the stainless steel bushed RAS roller tipped rockers look hard to beat. With the RAS rocker arms, you have no worries if an arm did somehow split sending needle bearings everywhere. Another advantage of the bushings is they tend to hold oil pressure in the shafts a little better than the caged needle bearings. They would be my 1st choice on any head utilizing standard factory offset rocker gear, a stout cam with street longevity in mind. Just my
Ed.
MoPower..... Better to be a racer for a moment than a spectator for a lifetime.
Re: What 1.6 rockers would you buy? [Re: 65 Belv A990] #258057
03/20/09 04:52 AM
03/20/09 04:52 AM
Arizona
Chris'sBarracuda Offline
Arizona
Re: What 1.6 rockers would you buy? [Re: Chris'sBarracuda] #258058
03/20/09 10:56 AM
03/20/09 10:56 AM
AndyF Offline
AndyF  Offline
Yep, the RAS stuff is a life time purchase. Buy that setup and run them forever on a street car. They are expensive to buy (when compared to the cheap Chinese stuff) but they'll last forever.
Re: What 1.6 rockers would you buy? [Re: Chris'sBarracuda] #258059
03/20/09 11:03 AM
03/20/09 11:03 AM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
Thanks Guys,
I am currently running the crane gold rockers but I am concerned with longevity. I try to drive my car as much as I can in the summer and reliability is important. I have sent an email to RAS and I am just waiting for a response. I do like the design of there rockers.
Thanks again for the responses!
Thanx 451 Guy
Re: What 1.6 rockers would you buy? [Re: 451Guy] #258060
03/20/09 12:27 PM
03/20/09 12:27 PM
AndyF Offline
AndyF  Offline
I'm not sure Gary even knows how to use email! Probably better call if you want a response from RAS.
Re: What 1.6 rockers would you buy? [Re: AndyF] #258061
03/20/09 01:00 PM
03/20/09 01:00 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
crane makes some ductile iron 1.6's for BBM's, they list at $27 ea at summitracing...
2017 Grand Cherokee Overland
Re: What 1.6 rockers would you buy? [Re: patrick] #258062
03/20/09 01:27 PM
03/20/09 01:27 PM
AndyF Offline
AndyF  Offline
Crane is an option. I'd recommend buying one pair of rockers first and checking the geometry to see how the pads line up on the valves. In my experience, the Crane nodular rocker arms don't always fit properly.
Re: What 1.6 rockers would you buy? [Re: AndyF] #258063
03/20/09 02:32 PM
03/20/09 02:32 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
Thanks Guys!
Maybe I will Call - I have the same e-mail issue on occasion!
Thanx 451 Guy
Re: What 1.6 rockers would you buy? [Re: 451Guy] #258064
03/20/09 02:39 PM
03/20/09 02:39 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
I'm also considering the RAS 1.6 rockers for the 493 buildup I'm doing. Any comments ( pros & cons) on cup versus ball ends on the adjusters?
Scott
Re: What 1.6 rockers would you buy? [Re: Scott58] #258065
03/20/09 04:07 PM
03/20/09 04:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think if you put them on the exhaust side your wasting
your money... even on a race engine... unless your
cam is WAY out of spec for the exhaust side, its not
like the intake side where you only have the atmospheric
pressure pushing the air/fuel in, on the exhaust side
the piston is pushing it out. For the street I wouldnt
waste the money..... JMO
Re: What 1.6 rockers would you buy? [Re: MR_P_BODY] #258066
03/21/09 09:37 AM
03/21/09 09:37 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Good point
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
