Vapor Separator #2579998
11/18/18 10:28 PM
11/18/18 10:28 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
Is there a company that makes a correct vapor separator (.060 metered return orifice, and correct internal lengths) for 3/8" line? From what I have seen on every thread I could find, there are some that are 5/16", but is there none that are made for 3/8" inlet and outlet? I emailed 521 Restorations and Classic Industries about this (haven't heard back yet), so if these aren't the ones for my application, are there any? I'll add to this thread when they email me back, because I doubt I'm the only one looking for a working 3/8" in and out separator, so no one will have to worry about this again.
Re: Vapor Separator [Re: 70charger512] #2580003
11/18/18 10:42 PM
11/18/18 10:42 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Nobody makes one with the .060 orifice. Franke Baldason has them with the screen inside like original. They didn't have 3/8 out back then. On the orifice, just get a bolt and drill it after cutting the head off and push in the return hose.
Re: Vapor Separator [Re: 70charger512] #2580119
11/19/18 10:28 AM
11/19/18 10:28 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I solder up the return orifice and then drill to desired size. keep in mind that HP440's and hemi's used higher pressure pumps that worked ok with a .060" orifice. lower pressure pumps should use a smaller return orifice.
Re: Vapor Separator [Re: lewtot184] #2580132
11/19/18 11:38 AM
11/19/18 11:38 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Ok, thank you, the orifice is only one the end so I don't have to solder up the whole tube correct? Also, what pressure would be good with a 440 stroked to 500"?
Re: Vapor Separator [Re: 70charger512] #2580209
11/19/18 02:48 PM
11/19/18 02:48 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
just do a simple solder of the 1/4" nipple and then re-drill to the size you want.
Re: Vapor Separator [Re: 70charger512] #2582259
11/24/18 04:34 AM
11/24/18 04:34 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
The Goodmark one RockAuto sells has the orifice.
https://www.rockauto.com/en/moreinfo.php?pk=5490264&cc=1078961&jsn=428
Re: Vapor Separator [Re: 70charger512] #2582264
11/24/18 07:11 AM
11/24/18 07:11 AM
WA
tman Offline
tman  Offline
WA
This is the info that 521 Restorations state on their separator. Some people said they have purchased from them and it seems to be correct.
http://vi.vipr.ebaydesc.com/ws/eBayISAPI...mp;secureDesc=0
Re: Vapor Separator [Re: tman] #2582304
11/24/18 12:25 PM
11/24/18 12:25 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It doesn't say anything about having the screen inside.
Re: Vapor Separator [Re: 71birdJ68] #2582515
11/24/18 07:43 PM
11/24/18 07:43 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
On their ebay the original diagram is pictured, which shows the screen, so I'm assuming that they wouldn't have no screen but show the correct diagram. Also the condition states they're in their original packaging.
Re: Vapor Separator [Re: 70charger512] #2582538
11/24/18 08:05 PM
11/24/18 08:05 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
So, these are NOS? I can only see part of the ad.
Re: Vapor Separator [Re: 71birdJ68] #2582569
11/24/18 08:50 PM
11/24/18 08:50 PM
None
71rm23 Offline
71rm23  Offline
None
Don't know NOS but per his ebay auction
Re: Vapor Separator [Re: 70charger512] #2582613
11/24/18 10:30 PM
11/24/18 10:30 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I've done some work with these separators and don't believe they are simply a bolt on and everything is good. the HP440 and hemi fuel systems were a "package" deal. they used higher pressure pumps than the standard v8's. the higher pressure pumps were necessary to compensate for the pressure lose of the .060" orifice. a 5-6lb pump will drive fine (HP440's and hemi's used 8+lb pumps) but may be a power lose (they were for me) vs the HP pumps. if using something like a 5-6lb mech pump reduce the orifice size to .035". I've found the 8-9lb mech pumps need about .075" (or more) to control the pressure and even at that there are big pressure swings at low rpm but will stabilize around 2000rpm at 7psi. of course a lot depends on how one intends to use their car.
Re: Vapor Separator [Re: 70charger512] #2582691
11/25/18 03:02 AM
11/25/18 03:02 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
For everyone that helped out and anyone that ever reads this thread:
521 Restorations sells the vapor separator with the correct lengths, correct .060 metered orifice, and the correct screen inside. I just received an email from them. Go buy your valor separator from 521 restorations.
Edit: They're repop, not NOS, but still has all the correct specs.
