Page 3 of 4 1 2 3 4
Re: Rear End Strength [Re: an8sec70cuda] #2553671
09/23/18 03:50 PM
09/23/18 03:50 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By an8sec70cuda
Originally Posted By GomangoCuda
Several people have mentioned That a back brace is a waste of time. Not exactly. It will not help ring and pinion life. It's real purpose on both 8 3/4 and 9" rears is to brace the housing so that it won't tow in and bend. Good power and dead hook can/will bend them.
By the time you start bending the 8.75 housing, you've already been breaking ring and pinions. For the money it costs to bandaid an 8.75, you could have built a Dana for it and forgotten about it.
^^ This ^^ Not to mention the time pissed away working on it.
Re: Rear End Strength [Re: Supercuda] #2553761
09/23/18 06:35 PM
09/23/18 06:35 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Originally Posted By Supercuda
Originally Posted By John_Kunkel
Originally Posted By jcc
It has yet to be proven what exactly could be deflecting with a 8.75. I am not convinced the ring is not also a contributor here.
I agree, deflection of both undoubtedly contributes to gear tooth failure and the avalanche that follows. I believe that, under severe stress, the carrier bearing preload disappears and allows the ring gear to be deflected enough to lose the contact patch.
Does it matter what is deflecting? Once either or both deflect it is all over.
It matters in the context of the original post. Ring gear deflection is not dependent on it being a 741,2 or 489.
Re: Rear End Strength [Re: 70charger512] #2553770
09/23/18 06:49 PM
09/23/18 06:49 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Does it matter, the diff or spool gets pushed out the back of the case. A billit cap helps but the case fails.
Have a great day
Iowan
"obsolete is neat"
Re: Rear End Strength [Re: John Brown] #2553793
09/23/18 07:56 PM
09/23/18 07:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By John Brown
Originally Posted By cudaman1969
Since you're going to use a clutch, there is a gizmo out witch is called the door closer. It fits on the clutch rod to slow down engagement just enough to reduce breakage of componites. Wish I had the manufacturs name, but look it up on line. I will use it on my car when done.
Clutchtamer?
Yes that's it, thanks. Looks like the Mustang and other small tire class are using this. I'll use it with my 23 spline trans behind the 520 Hemi. Just enough slip to live, street strip.
Re: Rear End Strength [Re: 70charger512] #2553814
09/23/18 08:32 PM
09/23/18 08:32 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
"Rear End Strength."
My wife used to have a lot of it...
Re: Rear End Strength [Re: lewtot184] #2553917
09/24/18 12:23 AM
09/24/18 12:23 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted By lewtot184
I think the real issue is the inner pinion bearing. the 742 has a larger bearing and a 489 is even larger. these are Timken bearings that control the thrust on the pinion. the larger bearing will have more control and less deflection......
1. I don't think small bearing size differences have any bearing (pun intended) on r&p deflection issues being mentioned here.
2. Not sure what you mean exactly on referring to "larger bearing", since I believe as shaft size increases the actual roller bearings get dispersed in a smaller area, since outer race dia remains the same(?), not sure how that has any impact on r&p deflection issue.
3. This means to me a 489 with a larger pinion dia shaft has less capacity bearings then the 742, but not sure that is an issue anyway with "thrust" overload, leading to likely failures
Re: Rear End Strength [Re: 70charger512] #2554104
09/24/18 03:16 PM
09/24/18 03:16 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
You can debate why until the cows come home, but the fact remains that an 8-3/4 in a heavy high horsepower car is going to break.
Re: Rear End Strength [Re: 70charger512] #2554119
09/24/18 04:11 PM
09/24/18 04:11 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
What is a "heavy" car exactly?
How about "high horsepower"?
popcorn
My nearly-complete Dart 451, 4-speed has a back-braced 8-3/4" with a Dr. Diff 3.91 sure-grip pumpkin, and 295-50R15 street tires. We shall see...
Re: Rear End Strength [Re: slantzilla] #2554157
09/24/18 05:33 PM
09/24/18 05:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not if it never hooks up.
Re: Rear End Strength [Re: John_Kunkel] #2554244
09/24/18 09:39 PM
09/24/18 09:39 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
There is that. haha
Re: Rear End Strength [Re: DrCharles] #2554382
09/25/18 10:29 AM
09/25/18 10:29 AM
an8sec70cuda Offline
popcorn
Your 8.75 will thank you for your tire choice. Like said before, if all you do is spin, you'll likely never break it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Rear End Strength [Re: an8sec70cuda] #2554528
09/25/18 03:49 PM
09/25/18 03:49 PM
dogdays Offline
dogdays  Offline
In response to the "ring gear is deflecting" train of thought, of course it deflects some. but I believe it's more pinion deflection. Basically the major thing the Ford 9" has over the 8 3/4 or 9 1/4 or 12-bolt is the pinion support. That's what seems to me to be making the difference between 8 3/4 and 9".
My friend with the '63 Corvette broke countless 12 bolts before switching to a Dana 60 and hasn't broken anything since.
R.
Re: Rear End Strength [Re: dogdays] #2554530
09/25/18 03:53 PM
09/25/18 03:53 PM
R.
I don't know, but..... If ring gear deflection isn't an issue then why do main bearing caps fail?
Re: Rear End Strength [Re: CSK] #2554615
09/25/18 06:05 PM
09/25/18 06:05 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By csk
I wasted $1200.00 on my 8.3/4 in my Charger, put Drag radials on it & killed the 8 3/4. NEVER will i spend money on 8 3/4 again. got a S60 from DR Diff with the S Trac carrier, it cost more but works AWESOME, I dont know my HP but car is heavy 4050 with me, so far 11.33 @ 121.1 1750 DA
Almost identical experience. I bought a $1300 clutch type sure-grip equipped 742 3rd member for mr 8 3/4 and killed the sure-grip within the first year. Drag radials, sticky track and manual valvebody all conspired to send the rear packing! I did Dr.Diff axles, spool and put ends off an 8 3/4 on a full floater Dana 60 truck rear. It gets abused regularly. Only problem I had was the screw in studs in my Dr.Diff axles were trash and started folding over. Replaced with Strange and all is good!
Don't ignore the driveshaft, either! I finally had to order a 1350 Strange unit to hold up along with u-bolt u-joint yoke instead of the strap type.
Last year my entire summer was spent fixing driveline issues. wrench
'63 Dodge 330
11.19 @ 121 mph
Re: Rear End Strength [Re: Pacnorthcuda] #2554629
09/25/18 06:18 PM
09/25/18 06:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, and the 9" pinion rear support doesn't help when the pinion tries to screw itself out the front of the housing.
Re: Rear End Strength [Re: Pacnorthcuda] #2554650
09/25/18 06:37 PM
09/25/18 06:37 PM
R.
Pinion flexes, teeth break and stack up b/t the pinion and ring gear...carrier gets bound up and pushed backwards, cracks the cap.
CHIP
Re: Rear End Strength [Re: John_Kunkel] #2554872
09/26/18 01:38 AM
09/26/18 01:38 AM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
Re: Rear End Strength [Re: 70charger512] #2579937
11/18/18 07:31 PM
11/18/18 07:31 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
Well looks like I'm going to revisit this thread. After reading these responses a couple months ago I decided to get a Moser Dana 60 (with moser axles, and a TrueTrac, since this is my daily, too) with MW billet caps. Are there any other things I need to do to strengthen it, or would a Moser 60 and billet caps be more than enough? It's funny reading through this thread how much info I left out. I plan on putting drag radials on (when going to the track), and it is still going to be stick.
Re: Rear End Strength [Re: 70charger512] #2579942
11/18/18 07:49 PM
11/18/18 07:49 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Honest 550hp drag radials and a stick in a heavy car....?
I like 8 3.4 rears for street cars. Not that combo though!!! Dana for sure IMO
CrAzYMoPaRGuY
Re: Rear End Strength [Re: 70charger512] #2579960
11/18/18 08:44 PM
11/18/18 08:44 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
way long ago in a land before time---SAE engineers rated the 8.75 good at 500 hp and the 9 inch at 450 hp----9 inch flaw-----the pinion is located at the bottom of the ring gear---that is the weakest position----it is strongest at the middle of the ring gear-------yes you can buy alot of stuff for a 9 inch because the aftermarket chased it-----like they chased the sbc....
Page 3 of 4 1 2 3 4
