Mini-Starters #2577817
11/13/18 05:02 AM
11/13/18 05:02 AM
Rio Linda, CA
John_Kunkel Offline OP
Rio Linda, CA
Most auto supply sources show year breaks like '95-'98, '99-'03, etc. but other sources like 440 Source show one-size-fits-all. What's the difference?
This is for a custom installation (early Hemi adapter), not an original installation.
Re: Mini-Starters [Re: John_Kunkel] #2577822
11/13/18 06:20 AM
11/13/18 06:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I know there are two one has more power.I run one for a 99 360 in my 12.5 440.Been in for close to 20 years.Still cranks like a /6.Mine Advance reman.My son ran a 440 source in his 413 for like 4 years.Still great when he sold the car.Rocky
Chrysler Firepower
Re: Mini-Starters [Re: John_Kunkel] #2577856
11/13/18 11:44 AM
11/13/18 11:44 AM
md
mopars4ever Offline
mopars4ever  Offline
md
IIRC, One was shorter then the other. Maybe have a parts store bring them both out and compare.
Re: Mini-Starters [Re: John_Kunkel] #2577864
11/13/18 12:16 PM
11/13/18 12:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I believe on the newer ones, the connector for the wire that goes to the starter relay is different.
Re: Mini-Starters [Re: DaytonaTurbo] #2577872
11/13/18 12:32 PM
11/13/18 12:32 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
iagree I think this is the main difference. Which doesn't really matter in most of our "old car" applications anyway because the plastic connector comes off. Just attach it to the studs.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Mini-Starters [Re: wingman] #2577904
11/13/18 01:38 PM
11/13/18 01:38 PM
moparx Online content
moparx  Online Content
doesn't the newer ones have a spade terminal for the solenoid vs the stud connection on the earlier ones ?
beer
Re: Mini-Starters [Re: John_Kunkel] #2577907
11/13/18 01:40 PM
11/13/18 01:40 PM
AndyF Offline
AndyF  Offline
They all physically fit the same with the same bolt pattern but the electrical connections were different over the years. There might also be internal differences. I have a handful of mini starters sitting on the shelf and they are all slightly different from each other but they all bolt on.
Re: Mini-Starters [Re: AndyF] #2577994
11/13/18 05:31 PM
11/13/18 05:31 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Mid 90's they went from a stud connection to a wire plug-in. Do a search on Ebay for Dodge Dakota starter by each year and you'll see the difference. I want to say around 96 is when they changed them????
Re: Mini-Starters [Re: John_Kunkel] #2578506
11/14/18 08:02 PM
11/14/18 08:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
As far as the connectors go '99 was the year they went to
one stud, and one plug-in connector.
A few years prior to that, they had two studs.
A few years prior to that, they had two studs with a plastic adapter bolted on...which had two more studs in it...often the plastic adapter had to be removed for retrofit.
Only reason I can remember '99 is several years ago I had to find the connector for the plug in style, due to MP selling the '99-2001 type for big block apps
Rich H.
Esse Quam Videri
Re: Mini-Starters [Re: John_Kunkel] #2579539
11/17/18 01:29 PM
11/17/18 01:29 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I bought a random one off amazon for my big block project. It ended up being the kind with an extension bolted to it. The extension hit my block so I had to pop off the plastic cover and unbolt it. The regular battery and trigger studs are still on there but they are very short so I had to install a seperate insulated stud instead of using my starter as the positive batt stud for my remote battery. On my last mini starter with remote battery I was able to stack a few ring terminals on it no problem.
Re: Mini-Starters [Re: radar] #2579653
11/17/18 08:23 PM
11/17/18 08:23 PM
Rio Linda, CA
Rio Linda, CA
I wound up ordering one of these:
https://www.ebay.com/itm/Starter-for-Chr...44/252920419051
Won't know if it works until my adapter gets here Monday. For $37 if it doesn't work I can just shelve it. whistling
Re: Mini-Starters [Re: John_Kunkel] #2579777
11/18/18 10:21 AM
11/18/18 10:21 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i bought one of those CHEEPIES of ebay(cant remember seller)i had to take it off and put it on another car then another car,i cant remember how long ago it was but that thing just wont die.one of the cars had a 13.5-1 comp. big block. shruggy
Re: Mini-Starters [Re: John_Kunkel] #2579880
11/18/18 04:44 PM
11/18/18 04:44 PM
CA
crackedback Offline
crackedback  Offline
CA
There are short and long versions. Mopardude318 ran into this when installing dougs 453 headers on a SB. He had the longer style which interfered and found a shorter version. Don't know if it was a V8 vs 6 deal or what. It was on FABO when he had the issue.
Re: Mini-Starters [Re: crackedback] #2580502
11/20/18 03:58 AM
11/20/18 03:58 AM
Pennsylvania
P
polaris400cc Offline
P
Pennsylvania
If you want the "miniest" of the mini starter with the actual bolt on terminals. I believe 97-98 Dakota with 318. Is the one ya want. I have had mini starters that didn't clear the brace between auto trans and engine block. But this one did. Was on a 73 318/904 challenger
