Re: I've got a fun one for you carb guys. [Re: Thumperdart] #2578827
11/15/18 05:11 PM
11/15/18 05:11 PM
Washington
madscientist Offline
Washington
Originally Posted By Thumperdart
Originally Posted By 67Charger
Dom,
Do you have an engine mild enough to test/tune my carb on? grin I can meet you any afternoon for a hand-off. I've got co-workers who live in Victorville that could deliver or at least get it close. I'm just west of you in Quartz hill and work at Plant 42. I may even throw in a Holley Ultra HP 950 that needs to be tuned for a 625HP Chevy 427 to be a driver, not a drag racer...
Don't need a "mild" motor to test on and most 4150's just get modded, assembled and shipped unless they're a BLP with a dual pattern base plate. Hit me up and I will set ya up and give you enuff BLP jets and bleeds to keep ya busy..... biggrin 760-900-3895.....
There you go 67charger. Dom is willing to help you out. Take the help.
Re: I've got a fun one for you carb guys. [Re: madscientist] #2578834
11/15/18 05:29 PM
11/15/18 05:29 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Dave beat me to it, but I would also isolate the secondaries and see what effect it has. Dom knows his stuff and I would get it to him asap.
Re: I've got a fun one for you carb guys. [Re: 67Charger] #2578881
11/15/18 07:20 PM
11/15/18 07:20 PM
Erda, UT
67Charger Offline OP
Erda, UT
Alright, the short version is that I'll soon be going to a 650DP from Dom. I have wanted to get away from the vacuum secondaries for a while, and I am finally going to pull the trigger.
The longer version is that I'm going to keep trying and learning in the meantime. I have an International Travelall with a 329 that is in desperate need of a carb, and the bigger displacement and lack of daily driver status will be more fitting to tinkering.
That being said, I am going to lean the idle screws out before leaving from work in a few hours, and tomorrow I'm going to lock out the secondaries.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: I've got a fun one for you carb guys. [Re: ZIPPY] #2578891
11/15/18 07:50 PM
11/15/18 07:50 PM
PA
Harry's Taxi 2 Offline
PA
Originally Posted By ZIPPY
What if you had a leak, between the main body and the baseplate.
(right about now is when somebody says it never happens)
A stock engine really shouldn't need to idle at 12.5:1. I understand if the mixture screws were enriched in as a test for driveability effects.
I have found warpage/leakage very common on 4150's.....both older and newer models. Brand new and used. 2300's also.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: I've got a fun one for you carb guys. [Re: 67Charger] #2578893
11/15/18 07:52 PM
11/15/18 07:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This will be fun in a few different ways............ thumbs biggrin
Re: I've got a fun one for you carb guys. [Re: 67Charger] #2579011
11/16/18 01:45 AM
11/16/18 01:45 AM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
hi
all this talk about carb , where is your timing at ?
if you hav a vac control on the dist un hok it and drive it for test .
to much timing at cruse may be your prob ?
just tkinkin out loud .
float level too low can cause these symptoms .
migh try a 10.5 pv also
Re: I've got a fun one for you carb guys. [Re: calrobb2000] #2579140
11/16/18 01:43 PM
11/16/18 01:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By calrobb2000
hi
All good points for sure but I never ever consider a VC Carb for anything no matter how mild and I put dp's on everything with success and lots of happy customers plus why use a variable(vacuum)for tuning when mechanical works flawlessly when tuned for the application......... thumbs
Re: I've got a fun one for you carb guys. [Re: calrobb2000] #2579634
11/17/18 07:11 PM
11/17/18 07:11 PM
Erda, UT
Erda, UT
hi
Second line of the original post:
Timing is 16° - 35° by 2800 (vac unplugged), Vac advance is in use
Fuel level is at the correct point in the windows.
10.5 PV caused all the extra fuel to come in WAY too often, like lightly accelerating at cruise from 65 - 70.
Re: I've got a fun one for you carb guys. [Re: 67Charger] #2579756
11/18/18 03:25 AM
11/18/18 03:25 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
If this was a warped base plate wouldn't it show up as lean on an AFR?
