Tailgate latch pull clips #2579357
11/16/18 10:58 PM
11/16/18 10:58 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
Who are the suppliers for the plastic clips that are used in the tailgate connecting the handle and rods to the latches?
Faith in every footstep, faith in every mile
Re: Tailgate latch pull clips [Re: psg] #2579462
11/17/18 10:14 AM
11/17/18 10:14 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Dorman and Motormite. Look in the help section of the parts store
Angry white pureblood male
Re: Tailgate latch pull clips [Re: psg] #2579687
11/17/18 10:58 PM
11/17/18 10:58 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
Thanks for the response but I'm fairly new to the forum and didn't understand the directions. I am familiar with the names Dorman and Motormite. psg
Re: Tailgate latch pull clips [Re: psg] #2579693
11/17/18 11:31 PM
11/17/18 11:31 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Your local parts stores have a section with HELP brand items.
What year truck? I wonder if they use the same clips the door lock rods use.
Facts are stubborn things.
Re: Tailgate latch pull clips [Re: psg] #2580235
11/19/18 03:40 PM
11/19/18 03:40 PM
Fitchburg, WI
BIGHOOK Offline
BIGHOOK  Offline
Fitchburg, WI
If it's a 3rd gen Ram (03-09), The (white) center handle rod clips are not available aftermarket at the auto parts stores. The dealer has them. Unfortunately, you have to purchase the entire handle assembly to acquire the clips. They do not list the clips separately under their own part number.
Same for the (green) outer rod end latch clips. Not sold separately. Aftermarket has the Dorman clips. They appear similar in design to the OEM clips but color is different (black) and are just a tad too small and will not fit the rod end.
I haven't opened up a 3rd gen door yet but those styles may also be used in there. However, it may be the same dealer situation - crack open your wallet for the whole assembly just to acquire some 50 cent rod clips! frown
Boneyard may be the best option. Or ebay. Lot's of late model new OEM Ram parts on there at 1/2 the cost of dealer.
Re: Tailgate latch pull clips [Re: psg] #2581558
11/22/18 03:46 PM
11/22/18 03:46 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
The truck is an '86 but the new tailgate is a '92. I have found some clips on ebay, going to try those based on measurements of rod and hole diameter. I'll post a comment once I find out if the fit is sufficiently close. psg
