Re: BB roller cam recommendations [Re: rick4106] #2570653
10/28/18 04:57 PM
10/28/18 04:57 PM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
My sons .496 has a .637 279@.050 roller with edelbrocks. Runs 6.00s in 1/8
Re: BB roller cam recommendations [Re: rick4106] #2570725
10/28/18 09:04 PM
10/28/18 09:04 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
No real benefit to limiting yourself to what’s available in a catalog.
Re: BB roller cam recommendations [Re: AndyF] #2579338
11/16/18 10:08 PM
11/16/18 10:08 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Originally Posted By AndyF
That would most likely work better than what the OP has now but my guess is that it is still 10 degrees too big. I tried a 270@050 cam in my 470 with TF heads and it was too big. That engine worked best with cams in the 260 range. The OP engine is a little smaller but has a bit more compression. My guess is the OP's engine will work best with a cam in the 260's.
As a reference, Dyno Sim gives me the best numbers with a 270/276 at .050
for my 12.5cr 470.....
Re: BB roller cam recommendations [Re: Wedgeman] #2579349
11/16/18 10:21 PM
11/16/18 10:21 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Does the simulator consider head flow? Does it give different results for flat-tappet vs. roller cams?
Re: BB roller cam recommendations [Re: rick4106] #2579360
11/16/18 11:11 PM
11/16/18 11:11 PM
W
Wedgeman Offline
Wedgeman  Offline
W
yes for both...........
Re: BB roller cam recommendations [Re: rick4106] #2579402
11/17/18 01:08 AM
11/17/18 01:08 AM
USA
B3RE Offline
B3RE  Offline
USA
Originally Posted By rick4106
Yes something in the combo is not working. My dart has a 446 with Sr heads that flow 290 and has a .557 mopar cam, speed pro pistons and a 750 carb. That car 6runs 6.60s @ 3300
A 290@.050 cam and Max Wedge port with only 446 cubes means you should be turning a lot of rpm to make power. Like ou812, I don't think it's making power on top. My first suspect when I see this is valvetrain instability, and may be why it's laying down. The bottom might be a bit soft from the big cam, but you could crutch that a bit with the converter. But, if it won't rev, that's an exercise in futility. Make sure the rocker geometry is right so the valvetrain stays stable, no matter what cam you choose to go with.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: BB roller cam recommendations [Re: rick4106] #2579460
11/17/18 09:29 AM
11/17/18 09:29 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
.700 Lunati
Re: BB roller cam recommendations [Re: rick4106] #2579493
11/17/18 11:51 AM
11/17/18 11:51 AM
gregsdart Offline
gregsdart  Offline
If the motor is 446 cubes and has 2.19 intakes, Vizards LSA chart asks for a lobe seperation that is rather tight. 104! If a single pattern 270 @ .050 cam is ground that way, the overlap at .050 would be 62 degrees, letting the motor breath. I definately don't have enough experiance to pick a cam that is perfect here, but looking at 62 degrees overlap combined with no more than 270 @ .050 total duration in straight up will allow a resonably early intake closing of 59 degrees ATDC. Sounds logical to me. Use a 6,000 + stall minimum due to the glide, shift it at 7,000?
Re: BB roller cam recommendations [Re: rick4106] #2579541
11/17/18 01:40 PM
11/17/18 01:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Hs 1.5 harland sharps and max wedge port.
Only made couple of passes with .650 lift 290@.050 old comp solid. 6.35@108.9.97@131 in 1/4.
I don't have "the" answer for you, but can give you something to think about. My RB 452 has less compression (11.5) and standard ports, but comparable flow #s. Dwayne Porter spec'd a 265 at .050 x .650" on 108 LSA solid roller, which made peak torque at 5100 and peak HP at 6900. Your MW ports would probably push the peak torque & HP RPMs up 300-400 over mine.
I don't recall what you may have for converter stall or what RPM you're willing to spin your engine, but you may be able to better predict what size cam suits your combination based on this.
