Re: 75 roadrunner k frame/ subframe
[Re: xs29l9g]
#2579453
11/17/18 06:18 AM
11/17/18 06:18 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
No, they change. Engine mount locations changes. Have the pics somewhere.
They can fit.. yes, but engine will be out of alignment by a tad, making a tight fit on all drivetrain mounts and could get some linkages issues
[Re: xs29l9g]
#2579511
11/17/18 12:35 PM
11/17/18 12:35 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
is the f frame/subframe the same on a 75 roadrunner between small block and big block? Not the same. While you can get the other type engine to bolt in, it's cockeyed. Back in my sailor days we swapped a 400/727/driveshaft and the entire front suspension out of an 78 Cordoba into what was a 318 75 Coronet. Tedious but everything bolted right up like factory, because it essentially was.
[Re: xs29l9g]
#2580176
11/19/18 01:46 PM
11/19/18 01:46 PM
RWG75
RWG75
75 and 76 factory part number books do list different part numbers for small block vs big block b-body k frames. Suspect other years will as well. As for what's actually different between them, couldn't tell ya and if there is in fact something different betting it would take meticulous measurement to figure out.
I've used boneyard donors from 73, 78 and 81 (original engines unknown) in to 75 and 76 small blocks. I've also dropped 440s in to 75s that I yanked the 318 out of. Even with keeping the original C body motor mounts they dropped in after swapping oil pans. If it's tweaked front/back side/side or diagonally I sure can't notice. As in: dropped right in to place like it was made for it and no fighting to get the holes lined up. Hood clears fine with OEM style intake / carb / filter, 440 fan fit in the 318 shroud, etc, etc.
Recall the same experience when putting the 318/904 in the C-body that was headed to the scrap yard after donating the 440/727. Dropped right in. Looked wrong as hell because of how small it was but again, no kinds of fighting to get the mount bolts in.
[Re: ]
#2580203
11/19/18 02:37 PM
11/19/18 02:37 PM
Posts: 16,828 Between Houston & Galveston TX
SattyNoCar
I've never done a small to big block swap, but, one other thing that is different (on '73's anyway) is the sway bar mount. Where the end links attach to the K. The mount for the link is welded in place. No sway bar? No mount. I'm just curious if this is why two part #'s are shown. If not, there should be three (or four?) part #'s then, correct? (the only factory V8 cars I've seen without a sway bar are small block cars).
John
[Re: SattyNoCar]
#2580451
11/20/18 01:28 AM
11/20/18 01:28 AM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
1974 Roadrunner
1967 Charger
[Re: ]
#2580461
11/20/18 01:48 AM
11/20/18 01:48 AM
Posts: 10,588 Freeport IL USA
poorboy
Freeport IL USA
Recall the same experience when putting the 318/904 in the C-body that was headed to the scrap yard after donating the 440/727. Dropped right in. Looked wrong as hell because of how small it was but again, no kinds of fighting to get the mount bolts in. This is Moparts. We can't let real life experiences over ride the book and part number thumpers. Every vehicle built has + and - tolerances. That would mean that anything may fit somewhere else, if the production shift is in your favor, or it may not fit if the production shift was not in your favor. The issue that has always been consistent when dealing with swapping a Mopar big block where a small block used to sit has always been an oil pan or an oil pump/filter clearance issue. My guess is that 9 out of 10 times, the big block clears everything, but if your writing a book, you have to cover your butt for that 1. Gene
[Re: Supercuda]
#2580848
11/20/18 11:23 PM
11/20/18 11:23 PM
Posts: 1,179 Canada
demon
Canada
Hacks gotta be hacking That photos tells it. Anyone remember the small block to big block swap mods on 73-76 A body K frames? I remember it required cutting the mount off the K frame, and moving it back about an inch on the left. Looks to me like the same principal applies here.
