Who Uses/Used Hastings Rings #257926
03/18/09 11:32 AM
03/18/09 11:32 AM
Lost in the ozone again
stubbs300 Offline OP
Vacation
Vacation
I've never heard of them. What's everybodies take on these? I have a chance to score some at a great price. Good, bad, comments, critiques, complaints. Thanks
Re: Who Uses/Used Hastings Rings [Re: stubbs300 ] #257927
03/18/09 11:36 AM
03/18/09 11:36 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Hastings has made engine components longer than you've been alive...Good stuff.. They don't market/advertise their stuff to the general public but they are well known in the industry...
Re: Who Uses/Used Hastings Rings [Re: 1_WILD_RT] #257928
03/18/09 11:46 AM
03/18/09 11:46 AM
United States
STLDuster Offline
STLDuster  Offline
United States
I have them in my engine, I am going to start it up for the first time here in a couple of weeks.
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Who Uses/Used Hastings Rings [Re: STLDuster] #257929
03/18/09 12:16 PM
03/18/09 12:16 PM
USA
b54406barrel Offline
USA
I have, do & will continue to. I've never had an issue with them. I still have pop's very old Hastings, pistol grip compression tester from his old bike shop I use. Its got the little stripe-shirted Hastings 'guy' on the face of the dial.
Re: Who Uses/Used Hastings Rings [Re: b54406barrel] #257930
03/18/09 12:46 PM
03/18/09 12:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
As good as any other rings IMO.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Who Uses/Used Hastings Rings [Re: MoparforLife] #257931
03/18/09 01:11 PM
03/18/09 01:11 PM
florida
74fldart Offline
74fldart  Offline
florida
Re: Who Uses/Used Hastings Rings [Re: MoparforLife] #257932
03/18/09 01:16 PM
03/18/09 01:16 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
We tore down an old 318 at a friends house and
rebuilt it with parts from a blown up 318.
the only thing new put in was a gasket set,
and timing chain set. The Hastings rings
from the blown up motor was used in the build,
and it did just fine in the 84 Dodge farm truck.
Oh, almost for got, we put in a new summit RV cam
and lifter kit.
Snap your neck, mega G-force launch, is all I want!
Re: Who Uses/Used Hastings Rings [Re: BDS871Cuda] #257933
03/18/09 02:48 PM
03/18/09 02:48 PM
They are good stuff but just a note--Hastings tend to have more radial pressure than other brands--they were very popular back in the "Re ring" days--they seemed to out do others in worn out bores and thus gained a good rep. I have used tons of them and never ever had a problem seating or otherwise.
Re: Who Uses/Used Hastings Rings [Re: 1_WILD_RT] #257934
03/18/09 03:51 PM
03/18/09 03:51 PM
I'm 60, and they've been making stuff longer than I've been alive. I don't know if they still make filters, their filters used to be excellent, probably better than Wix/ NAPA
and evidently...
http://www.hastingsfilter.com/
They need to fire their website people, though
Re: Who Uses/Used Hastings Rings [Re: stubbs300 ] #257935
03/18/09 06:34 PM
03/18/09 06:34 PM
I have some but haven't used them yet but they have always had a VERY good reputation
Re: Who Uses/Used Hastings Rings [Re: RapidRobert] #257936
03/19/09 11:14 AM
03/19/09 11:14 AM
Vacation
Vacation
OK, I gues I know what Rings I'm putting in BamBam! If anybody else has something to say, go right ahead. Thanks all.
Re: Who Uses/Used Hastings Rings [Re: stubbs300 ] #257937
03/19/09 11:25 AM
03/19/09 11:25 AM
they are a stock replacement type & especially their(3 piece) oil ring quality is really top notch compared to alot of the other non hi perf brands(which is not a deal breaker in itself) and you will have a larger gap on the compression rings as opposed to some file fit ones but with $$$ being tight & you having a good deal in front of you, nab em.
Re: Who Uses/Used Hastings Rings [Re: RapidRobert] #257938
03/19/09 12:19 PM
03/19/09 12:19 PM
By the way, I'd stick with "cast" rings especially for "home" rebuilds. The only real difference in ring life with chrome or other non--cast rings is wear resistance to DIRT and you shouldn't be getting dirt in there, anyhow.
Most of us don't drive a rebuilt engine far enough to wear out cast rings, and they AVOID a multitude of seating problems with chrome/ moly rings
Re: Who Uses/Used Hastings Rings [Re: stubbs300 ] #257939
03/19/09 03:10 PM
03/19/09 03:10 PM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
I have used them in 2- 318 builds and a 360 with zero problems.
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: Who Uses/Used Hastings Rings [Re: ] #257940
03/19/09 03:43 PM
03/19/09 03:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Original bore 340 here with about 50K hard miles on a hone and re-ring job with cast Hastings rings in 1993!
Still tests a ~140psi per clyinder. I cruise at about 3700-3800 rpm all day/night from L.A to Iowa in 50 or so hours.
Is it true that cast ring form to worn cylinder walls better than moly rings. Like that can take the expansion and contraction better??
Re: Who Uses/Used Hastings Rings [Re: autoxcuda] #257941
03/19/09 09:00 PM
03/19/09 09:00 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I reringed and repistoned my 360 in my van. #2 had munched the exhaust valve and left pitting in the cylinder wall. The valve was nowhere to be found! (JY motor)
Did a light hone on all the cylinders and dropped in iron rings. (a little more on #2) That was Jan 2001. The engine has 150-175K on a .040 over block. The guy that helped me rebuild it told me NOT to buy iron rings as they would probably not seat in that hole.
No problems and lots of hard use!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Who Uses/Used Hastings Rings [Re: stubbs300 ] #257942
03/19/09 09:48 PM
03/19/09 09:48 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Re: Who Uses/Used Hastings Rings [Re: earlybee] #257943
03/19/09 09:55 PM
03/19/09 09:55 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Some good info, http://www.hastingsmfg.com/ContentData.aspx?Contentid=82&Menu=AfterMarket
If only they could have some smaller print on their site!
Re: Who Uses/Used Hastings Rings [Re: earlybee] #257944
03/20/09 11:36 AM
03/20/09 11:36 AM
Vacation
Vacation
Thanks, After I put this topic up, I did a google and found there site. However, I did miss this. Will look it over good. BTW, The rings are cast that Im getting and I plan on a .40 over in a /6 with this. I can't wait to geterdone!
Re: Who Uses/Used Hastings Rings #257945
03/20/09 12:57 PM
03/20/09 12:57 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
Note to be a nit picker but all rings with the exception of some very high end race rings are made from cast iron. The better ones are ductile cast iron. Then the rings can have a chrome or moly coating on the wear face. The better moly ones use a plasma application process that is less likely to chip.
I agree though if you are just re-ringing an engine with maybe a bottle hone to break the glaze a plain iron ring is going to be less troublesome.
But it you are having the block bored oversize at a machine shop you really should spend the extra $30 bucks for a set of moly faced rings. There is no break in the second the engine starts they are seated, thats one of the reasons its not unusual for a new car to go 300K+ miles without a rebuild. Maybe you don't drive a lot of miles but its nice to know that you won't wear out the bores in your life time if you don't or can expect a couple hundred thousand miles if you do drive a lot.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
