Re: CalTracs on the street
[Re: babarracuda]
#88102
07/14/08 10:13 AM
07/14/08 10:13 AM
Posts: 20,207 Park Forest, IL
slantzilla
Park Forest, IL
I have run Cal-Tracs for many miles on the street, on my Duster and Dakota. They make the ride a little harsher, and you get a rattle from the linkage. (You should back off the preload on the street) You can use poly bushings in the spring eyes to take a small amount of the harshness away, and you can make nylon or rubber "bumpers" for the tops of the springs to quiet the rattles down too.
[Re: bonefish]
#88105
07/14/08 04:38 PM
07/14/08 04:38 PM
Posts: 143 Buenos Aires, ARGENTINA
madmax2
Running you on the street with Caltrac's Mono-leaf?
'70 Dodge GTX sb 418ci (Early A-body), Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator, Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
[Re: slantzilla]
#2579084
11/16/18 11:58 AM
11/16/18 11:58 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
I have run Cal-Tracs for many miles on the street, on my Duster and Dakota. They make the ride a little harsher, and you get a rattle from the linkage. (You should back off the preload on the street) You can use poly bushings in the spring eyes to take a small amount of the harshness away, and you can make nylon or rubber "bumpers" for the tops of the springs to quiet the rattles down too. Man this is an old thread, but I didn't want to start a new one for this small of a question, is it bad to run 0 preload on the street?
[Re: 70charger512]
#2579142
11/16/18 01:48 PM
11/16/18 01:48 PM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
Bad in what way? Noise, ride, handling, traction? Are you using monoleafs, ss springs or stock springs? What shocks?
I have tried everywhere from 1/4" gap to 1 full turn preload with monoleaf springs. Now I just set the left at 0 and the right at 2 flats preload and call it done. I am going to guess that if you are more than 2 flats tighter or looser than this that you are lost and should be working on the shocks instead.
In my post above from TEN years ago I suggested heater hose to soften the noise. That worked but the hose wore out fairly quick. I now have a piece of 1/4"thick flat polyurethane glued to the top of the springs with 3M weatherstrip adhesive. It is holding up much better.
[Re: GomangoCuda]
#2579939
11/18/18 07:34 PM
11/18/18 07:34 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
In my post above from TEN years ago I suggested heater hose to soften the noise. That worked but the hose wore out fairly quick. I now have a piece of 1/4"thick flat polyurethane glued to the top of the springs with 3M weatherstrip adhesive. It is holding up much better. No, sorry, I just meant if it will negatively affect the Caltracs with no preload. I'm not worried about noise, and everything else should be normal with no preload correct? and I'm also most likely keeping the XHD springs, since Calvert said there wouldn't be any problems (although I will probably have to have a little more preload on one side, no biggie at all)
[Re: babarracuda]
#2580303
11/19/18 07:24 PM
11/19/18 07:24 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Nothing wrong running zero preload.
