4 vs 5 frictions in a 904 #2579053
11/16/18 06:59 AM
11/16/18 06:59 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
Is there a difference in performance between using 4 clutches and 5 clutches in a front drum on a 904?
My original trans builder managed to fit 5 but used 4 thick frictions(Borgwarner)and 1 thin (Alto) with a machined pressure plate to get it to fit.I have 5 thick which only gets me .035 in clearance. After looking at the original frictions it explains why one looks different in colour its .062 instead of all the others. If 4 clutches will be enough handle a 450hp 360 I'll just use a stock pressure plate i have lying around and put it together with 4 clutches.
Re: 4 vs 5 frictions in a 904 [Re: hysteric] #2579088
11/16/18 12:08 PM
11/16/18 12:08 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
You always get more holding power by adding surface area, more clutches. Different manufacturers make different thickness clutches and steels. Many make specialty clutch steel combinations to increase holding power in drums. Many rebuilders have lots of different clutches laying around, as long as the clearances are correct stack as many as you can get in the drum. If you bought a stock trans kit, you will most likely only get 4 clutches in the pack. If you want more you will have to buy a different clutch and steel.
Re: 4 vs 5 frictions in a 904 [Re: hysteric] #2579137
11/16/18 01:38 PM
11/16/18 01:38 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
It is good to see you are doing the rebuild yourself. It's not that difficult and you'll know what you have when you're done.
Since you're in there I'd go for 5. I've had good luck with Alto Red fibers and Kolene steels. Like jbw123 noted - you can get different thickness fibers and steels to make room.
I'd also check all tolerances since you didn't originally set this one up. Set everything on the tighter end of the specs.
I'd purchase Carl Munroe's book: https://www.amazon.com/Torqueflite-727-Transmission-Handbook-HP1399/dp/1557883998. There's still lot's relevant information in there.
If you're interested, I'll send you my 904 build notes for reference.
Re: 4 vs 5 frictions in a 904 [Re: hysteric] #2579170
11/16/18 02:38 PM
11/16/18 02:38 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Rear clutch frictions are .063, and other than being thin, are interchangeable with the thicker front clutch plates. Steels are also available in .068 and .080. Snap rings also came in different thicknesses if you have an assortment of those. Cutting the pressure plate like that makes it a PIA to measure clearance and weakens it.. Use an uncut pressure plate or on the outside chance that you have to trim it some, trim the entire width. Use good hi-energy or blue rear clutch plates (12760), along with a mix of thick and thin steels to dial the clearance in. Measure and adjust clearances before oiling everything for assembly. At .012 per disc, that's .060 total clearance. You should be able to get very close to that just adjusting part thicknesses.
Re: 4 vs 5 frictions in a 904 [Re: CMcAllister] #2579218
11/16/18 04:39 PM
11/16/18 04:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This was recently discussed; rear clutches are not intended to apply under power and are, therefore, different.
Re: 4 vs 5 frictions in a 904 [Re: hysteric] #2579245
11/16/18 05:33 PM
11/16/18 05:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
That was true of the OEM stuff. Not so much the present aftermarket pieces. We aren't worried about Grandma complaining about a harsh shift.
Re: 4 vs 5 frictions in a 904 [Re: hysteric] #2579292
11/16/18 07:48 PM
11/16/18 07:48 PM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
Thanks Humpty. I have both Munroe's and Tom Hand's book for reference as well as the ATSG manual. It certainly has taken the mystery out of transmissions and the reason to pay some one else to build them for me again.
Yeah the machined pressure plate is a PITA to check clearances but i can understand why it was done that way. I'll have to see if i can 5 thins for the front clutch and correct clearance with a different pressure plate. Otherwise ill just throw the original thin clutch back in as it looks good.
Thanks again guys.
Re: 4 vs 5 frictions in a 904 [Re: hysteric] #2579353
11/16/18 10:49 PM
11/16/18 10:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
the better fibers are grooved (not waffled) and can be used in either clutch pack.
Re: 4 vs 5 frictions in a 904 [Re: hysteric] #2579428
11/17/18 02:51 AM
11/17/18 02:51 AM
Guitar Jones Offline
You can check the clearance with a dial indicator easy enough.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 4 vs 5 frictions in a 904 [Re: hysteric] #2579430
11/17/18 03:08 AM
11/17/18 03:08 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
That's how i measured it.
