Re: BESTest headlight cover renewer ?
[Re: AARCONV]
#2578788
11/15/18 03:56 PM
11/15/18 03:56 PM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Polishing compound. Gotta love that consumer packaging.
Master, again and still
[Re: Sunroofcuda]
#2578923
11/15/18 09:04 PM
11/15/18 09:04 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I bought a pair of aftermarket ones from the internet ("Eagle Eyes" brand) & they were perfect fit, & functioned MUCH better than the OE ones. This is what we did as well. Same result.
I have mechanical Aptitude. I can screw up anything.
[Re: Supercuda]
#2579019
11/16/18 02:29 AM
11/16/18 02:29 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
If you don't want to buff your headlights periodically (and you will), check out Rock Auto's prices on headlights. I buffed mine for several years, but when I broke one (not in the buffing process), I replaced them both. Wish I would have done it sooner. This This again !!
[Re: wingman]
#2579083
11/16/18 11:57 AM
11/16/18 11:57 AM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
The 3M kit is the best I have used and works well.
Eventually, though the UV rays will do their thing again. I bought a 3M kit on sale, $36 I think it was - kind of on a lark, figured I'd try it - and yeah, it cleared up the headlamps on our minivan and came out nice... but as mentioned already, the UV just started all over again, plus the tiny spider cracks are in it now. So I just ordered in a new set of headlamp assemblies from RockAuto.. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: dOoC]
#2579165
11/16/18 02:30 PM
11/16/18 02:30 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
body section 2005 Ram headlights I usually buy the midrange options. Replaced them on several different different vehicles over the years, never had them long enough afterwards to have them go hazy again.
[Re: dOoC]
#2579173
11/16/18 02:43 PM
11/16/18 02:43 PM
Posts: 16,492 On the run…
BloFish
On the run…
Is there a rockauto discount code available?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2579335
11/16/18 10:03 PM
11/16/18 10:03 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yes, check retailmenot for a 5% code. But also check with Ebay. They usually beat Rockauto on Headlights and the like.
[Re: dOoC]
#2579359
11/16/18 11:03 PM
11/16/18 11:03 PM
Supercuda
About to go away
About to go away
up yours
9238848886853244
discount code for RA
[Re: dOoC]
#2579380
11/16/18 11:44 PM
11/16/18 11:44 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Sand them with 1000 grit wet then a cote of clear urathane. You will never have to mess with them again.
Have a great day Iowan
"obsolete is neat"
[Re: dOoC]
#2579607
11/17/18 04:45 PM
11/17/18 04:45 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
I did the ones on my wife's sentra, and the ones on my Grand Cherokee.
Sanded them, 400, 600, 800,1000 grit, then clear coated. About three years later they still look pretty good.
