Piston/Rod Help- 572 Hemi #2473289
03/28/18 01:10 PM
03/28/18 01:10 PM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
I have a 4.5 Block with a 4.5 Crank.
What Rod Length and Compression Height should I use to get Pump Gas Compression with Aluminum MP heads.
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1997 Ram B3500 Van 5.9
1991.5 W250 Cummins- Big Chief
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2473307
03/28/18 01:58 PM
03/28/18 01:58 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Most everybody uses a 7.1"/.990 pin rod for that. Hopefully your crank is 2.20 pins. Make sure of the width. It's easier to find rods if your crank pins are Chevy width. Compression height doesn't tell you everything on a Hemi because of the dome. Just call Ray Barton and tell him what you have and he will get you pistons. I have a beautiful set in my shop. I can get you the number if you need it.
2011 Drag Pak Challenger
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2473313
03/28/18 02:10 PM
03/28/18 02:10 PM
I have a new World 4.500 bore block that I'm building a 572 C.I.pump gas motor for a local customer with FHO CNC ported Stage V street heads, I used a set different set of rods(Manley SS I beam rods) and had Diamond make the pistons. This motor ended up with 11.04 to 1 compression ratio due to me thinking those heads would be 175.0 CC, they aren't shock Their 169.8 CC shruggy
They can make what ever piston compression ratio you want or need as long as you know the stroke, bore size you want, head CC size, rod length and wrist pin size up scope
Most of the other decent piston companies will do that also for you thumbs
Re: Piston/Rod Help- 572 Hemi [Re: rickseeman] #2473316
03/28/18 02:15 PM
03/28/18 02:15 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Look at that weight. Nice. And the pin doesn't go into the oil ring. Nice. Gas ported. Thin rings. (But I wouldn't be afraid to go thinner.) Modern pistons like these are one of the reasons why Hemi's make 800 HP today instead of 425. Life is good.
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2473361
03/28/18 03:34 PM
03/28/18 03:34 PM
an8sec70cuda Offline
Mine uses 7.00" BBC rods. Custom Diamond pistons spec'd for big nitrous. It is around 11:1 w/ MP aluminum heads. The folder w/ all the info on it is at home...I can get you my measurements tomorrow.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2473372
03/28/18 04:03 PM
03/28/18 04:03 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I am not worthy. Mine is only a 528" Hemi.
Custom (Nitrous) 10.5:1 Compression (pump gas, street car)
1/16, 1/16, 3/16, didn't go hi-tech on ring pack due to street driven
Mopar Heads, 10.5:1 Compression, 2.250"/1.900" Valves
4.503" Bore
4.150" Stroke
7.100" BBC Rods
CH 1.370" (I think) I would have to look at my build sheets again also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2473385
03/28/18 04:39 PM
03/28/18 04:39 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Before you buy pistons, check with ICON pistons. They are United Engine & Machine Co. Have been making pistons since 1923. Longer than anyone else in the country. They made the first aluminum pistons. You will not find a better quality piston, or better price. Not really a sales pitch, just facts. Call Daniel or Glen at 775-882-7790
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2473387
03/28/18 04:48 PM
03/28/18 04:48 PM
DC, MD Suburbs
DC, MD Suburbs
JE Pistons for Chrysler Mopar 426 HEMI Dome 4.530" Bore 251334 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F183148524089
I saw these on ebay. My block needs to be over-bored
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2473418
03/28/18 05:44 PM
03/28/18 05:44 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I missed that part on mine. My pistons are JE's. Nothing wrong with JE, ICON, Diamond or Gibtec's.
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2473539
03/28/18 09:08 PM
03/28/18 09:08 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I am using 7.100" rods with CP pistons .
1.37 compression height .064 , .064, .218 ring pack.
Pistons weight 703 grams.
572"
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Piston/Rod Help- 572 Hemi [Re: Hemi Allstate] #2473765
03/29/18 11:34 AM
03/29/18 11:34 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
My 572 has custom CP pistons and Callies 7.1 rods
Re: Piston/Rod Help- 572 Hemi [Re: an8sec70cuda] #2475911
04/02/18 10:52 AM
04/02/18 10:52 AM
A lil late, but as promised...
CHIP
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2576860
11/10/18 07:52 PM
11/10/18 07:52 PM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
DoubleD any info on those cp pistons? Spec sheet possibility. What crankshaft are you running?
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2576925
11/10/18 10:19 PM
11/10/18 10:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Much as it's never been in style to say anything nice about Indy, Diamond makes a stocking/shelf piston for them that looks pretty nice with a 7.100 rod. It does use support rails for the oil ring pack.
It uses a 990 pin, has 1.35 compression height, weighs 695 grams and uses standard 1/16-1/16-3/16 rings. There aren't any tricks in them, just a relatively short compression height. Has a 73.9 cc dome per specs, I have not CC'd yet. 804IN is the package number.
Rich H.
Esse Quam Videri
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2576971
11/11/18 12:46 AM
11/11/18 12:46 AM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
Also any info from you Hemi Allstate. Must be a similar piston?
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2577050
11/11/18 10:57 AM
11/11/18 10:57 AM
The Great White North
RAMM Offline
RAMM  Offline
OP you can't go wrong with any piston MFG that has been mentioned, however , after touring JE pistons facility this year at EMC and using 2 sets of them recently I doubt anyone else can meet their quality vs price. My vote is to call Ron Beaubien @ Diamond or Jim Irwin @ JE and tell them what you want. Either will deliver. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2577527
11/12/18 04:15 PM
11/12/18 04:15 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Mine are listed as 1.34"
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2578475
11/14/18 06:32 PM
11/14/18 06:32 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Don't be scared of thin rings. 1 millimeter , 1 millimeter and a 2, or 3 millimeter oil is very common now.
Re: Piston/Rod Help- 572 Hemi [Re: 440PURSUIT] #2578628
11/15/18 02:40 AM
11/15/18 02:40 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I bought a set of NOS $250 mopar performance weisco slugs and got the K1 6.86 rods and K1 4.5 stroke crank with standard Hemi Journals...Had less that $1600 into the complete rotating assembly including balancer and 130 tooth flywheel. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
