Re: BESTest headlight cover renewer ?
[Re: dOrk !]
#2578355
11/14/18 01:44 PM
11/14/18 01:44 PM
Posts: 8,396 Highland, MI.
Sunroofcuda
Highland, MI.
....or are they either a waste of time and money or at the best jst temporary ? If you can buy an inexpensive reproduction new, that is the route to go. For my wife's 300M, the OE headlights were getting hazy & never illuminated the road in front of you at night very well. I bought a pair of aftermarket ones from the internet ("Eagle Eyes" brand) & they were perfect fit, & functioned MUCH better than the OE ones. They have been on the car for 2 years now & still look perfect.
[Re: Sunroofcuda]
#2578372
11/14/18 02:05 PM
11/14/18 02:05 PM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
The 3M kit is the best I have used and works well.
Eventually, though the UV rays will do their thing again.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: dOrk !]
#2578427
11/14/18 04:31 PM
11/14/18 04:31 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
I did the ones in my old Ram. Sanded with 1000 grit then polished with the 3M stuff and a Powerball. Cleaned them really well and coated them with Valspar Marine varnish. They still looked good when I sold the truck a year later.
[Re: Fat_Mike]
#2578562
11/14/18 10:55 PM
11/14/18 10:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you don't want to buff your headlights periodically (and you will), check out Rock Auto's prices on headlights. I buffed mine for several years, but when I broke one (not in the buffing process), I replaced them both. Wish I would have done it sooner. This
[Re: dOrk !]
#2578572
11/14/18 11:18 PM
11/14/18 11:18 PM
Posts: 12,082 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you want to polish them, you don't have to buy anything special. Any polish will do the job. Depending on how rough the surface is, you can start with anything between 600 and 1000 sandpaper. Finish with 1500 or 2000.
The plastic is soft enough that you don't need compound. Polish will do it. It would go a little quicker if you use some compound, but not much if you use some 1500 to 2000 paper. And don't let the surface go dry. The plastic will burn and smear much easier than paint.
If you decide to polish them, they usually look better and are clearer. But you will need to redo them periodically.
As mentioned above, the best and fairly permanent fix is to spray them with catalized clear after sanding with 600 or so sandpaper. Spray bomb clear doesn't work, it just lays on top of the plastic and looks like fish eye.
We spray the headlights in just about ever car we get in. It is amazing how headlights that are yellow and completely fogged look almost new after clearing.
Either way, it is important to sand the surface enough to remove the oxidation and old sealer.
Master, again and still
[Re: dOrk !]
#2578674
11/15/18 11:49 AM
11/15/18 11:49 AM
Supercuda
About to go away
About to go away
up yours
Ooooops .....what kind of money are new ones ? rockauto.com
