Page 4 of 6 1 2 3 4 5 6
Re: Dana 60 [Re: Uberpube] #2577475
11/12/18 01:35 PM
11/12/18 01:35 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Boy, this thread has gone all over the place. We all have our own personal preference. I believe a Dana belongs under a Mopar. I like the OP's idea. Find a truck Dana and put it together for his car. I want one of those magnesium Dana 60's like Ramchargers used to sell. If I can't find one of those, I want one of these. I know it's a 9" and I hate those but it's pretty and I can't resist that.
2011 Drag Pak Challenger
Re: Dana 60 [Re: pittsburghracer] #2577478
11/12/18 01:42 PM
11/12/18 01:42 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I put this aluminum Dana 60 in a friend's 71 Cuda a few years ago.
Sheldon
Re: Dana 60 [Re: cdwmotorsports] #2577480
11/12/18 01:52 PM
11/12/18 01:52 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
Who makes the aluminum case Dana 60?
Re: Dana 60 [Re: RUNCHARGER] #2577504
11/12/18 03:03 PM
11/12/18 03:03 PM
That is probably one of those rare Mag case Dana 60 with the aluminum rear cover up scope
Don Garlits had one of those in the back of one of his early(1975 maybe) black Dodge single wheel four door pickups at the Winternationals that year, I made a comment about that I would like to have one like that grin He no you don't , it is broken work shruggy
Mopar had a batch of them made and gave them to a lot of their sponsored racers and then no more where made after that so it was probably due to the case not holding up in drag cars work twocents
Rickseeman, how much is one of those pretty racing rear ends like that one now ? Is that a Mark Williams racing rear end?
How about the racing 12 inch rear ends like that?
My new car has a cut down pickup 3/4 ton Dana 60 in it, hopefully it will hold up to what I throw at it luck
Re: Dana 60 [Re: Cab_Burge] #2577512
11/12/18 03:19 PM
11/12/18 03:19 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
That billet 9" housing is sold by Tim McAmis for $9,000.
Strange and Chrisman make the 12" rears. But I don't think they have ratios that we could use.
And yes, Bigs used the mag Dana 60 rears. Bigs was super weight conscious.
Re: Dana 60 [Re: rickseeman] #2577662
11/12/18 10:45 PM
11/12/18 10:45 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The one that RUNCHARGER posted is a piece that Lee posted about a few years ago. I'm not sure it's from Australia or another offshore deal but it's a Dana style center with tubes that slide in and have like eight bolts holding them in.
Not the same style as the Ramchargers unit.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Dana 60 [Re: cdwmotorsports] #2577850
11/13/18 11:26 AM
11/13/18 11:26 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The Obvious,
Nothing looks as good as a dana under a street mope, period, end of story.
For a race car,,,,if you already have one, and you're a bracket racer, sure why not. tough, tough, tough, rear end. Starting from scratch,,,ehhh, a 9 makes so much more sense.
Reality is however, there are no fast cars on a dana.
Re: Dana 60 [Re: dthemi] #2577929
11/13/18 02:42 PM
11/13/18 02:42 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted By dthemi
The Obvious,
All true. I would use a 60 in the right application. But on a fast car, big tire, narrow 4 link C-C, need for heavy duty, light weight aftermarket parts and gear ratio options, it's really not an option. There is so much stuff to be attached to the housing in a limited space, the one piece steel housing is almost a necessity.
Re: Dana 60 [Re: cdwmotorsports] #2578078
11/13/18 08:45 PM
11/13/18 08:45 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Why not do that special pumpkin that fits a dana 60 gear set that fits into a 9" housing?
But I put dana 70 gears into a 60 housing...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Dana 60 [Re: cdwmotorsports] #2578123
11/13/18 10:03 PM
11/13/18 10:03 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
To be real true fast cars don't have a 9" ford rear end. They have a drop out center section race axle.
68 Barracuda Formula S 340
Re: Dana 60 [Re: astjp2] #2578138
11/13/18 10:25 PM
11/13/18 10:25 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Theres a twelve bolt Chevy center for a 9" Ford housing.
Have a great day
Iowan
"obsolete is neat"
Re: Dana 60 [Re: cdwmotorsports] #2578195
11/14/18 12:09 AM
11/14/18 12:09 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The 12 bolt design is a bit more efficient than the 9". Guys who use that are typically lightweight, not tons of power and willing to do whatever it takes for the last bit of performance. Think Comp.
Re: Dana 60 [Re: CMcAllister] #2578379
11/14/18 02:29 PM
11/14/18 02:29 PM
Minn
SportF Offline
SportF  Offline
Minn
Anybody ever seen a definitive/scientific test of rear end drag? Never heard of one. There was a magazine that did some tests, but as unscientific as it comes.
In fact, that took so much effort I am astounded that they did it when it all could have been done on a bench.
As such, this power robbing 9 inch story carries on and on, and will never end.
I find it amusing.
Re: Dana 60 [Re: SportF] #2578388
11/14/18 02:46 PM
11/14/18 02:46 PM
Locomotion Offline
Locomotion  Offline
I find it amusing.
There have been tests & comparisons, but I don't have a link. The differences aren't a lot, but they are there. Most has to do with the pinion position relative to the ring gear. The closer to center the pinion is, the less contact surface the teeth have, thus less friction. Ford 9" also has an extra pinion bearing, I believe. The order I remember is : 12 bolt, Dana 60, 8 3/4, Ford 9". I don't recall any other rears, but the 10 bolt would probably be pretty efficient, if you didn't have a lot of torque/HP/weight.
I believe Jim Kinnet had a 12 bolt in his SS/AA cuda and a fast Stock class racer had a 8 1/4" rear in his car till durability issues and lack of ratios encouraged him to change to a Dana 60. This is also partially why many haven't seen a performance loss going from a 8 3/4 to a Dana 60. It may be bigger & heavier, similarly optioned, but the Dana is more efficient, especially if you take the weight difference out from elsewhere in the car.
Re: Dana 60 [Re: astjp2] #2578390
11/14/18 02:57 PM
11/14/18 02:57 PM
Locomotion Offline
Locomotion  Offline
It may have been Mark Williams who makes/made a 9" Ford center with 12 bolt innards!
Re: Dana 60 [Re: SportF] #2578399
11/14/18 03:17 PM
11/14/18 03:17 PM
Washington
madscientist Offline
Washington
I find it amusing.
There have been tests. The HP loss (or gain) is found in the gear ratio.
The lower the gear, the better the Dana is. Once you get lower than 4.88 the Dana gets better. IIRC, way back in the day the break even point was 4.10ish with anything taller than 4.10 and the 9 inch was better.
As for weigh, I've seen it published, but who did the test I don't recall. There wasn't 10 pounds difference between any of the rear axles when you build them to be raced with.
Re: Dana 60 [Re: cdwmotorsports] #2578400
11/14/18 03:17 PM
11/14/18 03:17 PM
Minn
SportF Offline
SportF  Offline
Minn
Put a rear on a bench, put a "load cell" on the pinion. Measure bearing preload and subtract that from end result.
Put a 3 foot bar (length not really a factor), and a weight on end of bar fasten to axle. Measure effort from 6 to 11 O'clock at cell. Graph it.
Repeat for all rears.
Would you use a "9" if you found it to be within .05% of other rears? How about 1%? What if its within .005%?
I know 3 people personally that traveled long distances to race, only to loose a Dana in time trials. About then they probably would have given 5% up just to race.
Can we talk a magazine into doing this kind of test? I know this all off topic, but somewhat relative anyway.
Re: Dana 60 [Re: SportF] #2578402
11/14/18 03:22 PM
11/14/18 03:22 PM
Washington
Washington
All parts fail. I've seen my share of 9's fail. 99.9999% of the time is user inflicted. So saying not to use an axle because someone drove somewhere and broke something is silly at best.
Why would anyone want (or even care what any magazine says) a magazine to do a test of anything? I've been reading car, dirt bike, gun and other magazines since I could read. I've never seen a single test I could conclude was done correct. Not one.
Those magazines exist to sell advertising. Period. The LAST entity I want testing anything is a magazine. That includes video magazines that are just as bad.
Re: Dana 60 [Re: madscientist] #2578408
11/14/18 03:36 PM
11/14/18 03:36 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Only on Moparts can a rearend discussion turn into a lab experiment. Lol 😂
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dana 60 [Re: cdwmotorsports] #2578415
11/14/18 03:49 PM
11/14/18 03:49 PM
Minn
SportF Offline
SportF  Offline
Minn
Well, ha ha, all correct above. Yeah, parts fail. Its just that I have yet to see an after market 9" fail. Stock, yeah.
Years ago when I was setting up my first aftermarket 9" I went to San Diego Gear and Axle to get a bearing. In talking with the owner, he said "I've got one of those in my Funny car, been there forever without problems."
Made me feel good about the money I had spent.
Carry on, good luck to all, no matter what kind of rear you like.
