Page 1 of 3 1 2 3
sway bars, worth it? #2578374
11/14/18 02:11 PM
11/14/18 02:11 PM
RapidRobert Offline OP
Early A body. daily driver. easy driven around town. would it show much difference in turns/be worth the investment? thank you for your time.
Re: sway bars, worth it? [Re: RapidRobert] #2578380
11/14/18 02:29 PM
11/14/18 02:29 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I like them on my street car B-body
Re: sway bars, worth it? [Re: 451Mopar] #2578386
11/14/18 02:43 PM
11/14/18 02:43 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i took them off my 69 b-body,never noticed a diff.my car is just a mid 10 sec street strip car, i dont really pull any Rockfords or twisty road driving.
Re: sway bars, worth it? [Re: RapidRobert] #2578387
11/14/18 02:44 PM
11/14/18 02:44 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
RR,
It will improve your handling, but your satisfaction will depend how sensitive you are to it. Yes, I think you will feel a difference. It would turn crisper, flatter, and create a little more understeer with a front sway. Add a rear sway and it'll go back to neutral and be much flatter in harder turns. Include stiffer shocks and your handling will be even one more step crisper. Larger, wider rims with better tires takes you another step... The more steps you take, the less comfortable it will be on the street.. Sways are a good first step.
How necessary it is, is up to you. Sways, shocks, rims, tires, are not expensive steps, easy to install, and each one improves your handling. At some point consider front discs to stop you better. But that's more money.
EXAMPLE: I like to track race, so I put a 9lb FirmFeel tubular sway on the front of our '65, plus a rear sway.. plus stiffer shocks.. plus stickier, wider tires but stayed with 14" rims (Ford 6.5") to absorb harshness.. I have a very reasonably soft ride with much tighter, flatter handling than before..
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: sway bars, worth it? [Re: RapidRobert] #2578392
11/14/18 02:58 PM
11/14/18 02:58 PM
BeavisHQV Offline
BeavisHQV  Offline
changed the front to a thicker one, added one in the rear + new pst-shocks. Huge improvement. But i have a heavier b-body.
And thanks again for your help in several question!
Re: sway bars, worth it? [Re: RapidRobert] #2578396
11/14/18 03:06 PM
11/14/18 03:06 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
I added a rear and a thicker front to my Challenger and it made a big difference during hard turns.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: sway bars, worth it? [Re: RapidRobert] #2578420
11/14/18 04:11 PM
11/14/18 04:11 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
One of the first things I did to my Fifth Avenue was a set of matched cop car bars. Car originally only had a front 1 1/16" bar. The cop bars measure 1 1/8" and 0.75". It made a huge difference in regular street driving and changing lanes on the interstate. Honestly, it made it safer to drive.
If I was daily driving and old car I'd match a set of big sway bars and go soft on the torsion bars.
Re: sway bars, worth it? [Re: MarkZ] #2578433
11/14/18 04:55 PM
11/14/18 04:55 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I bought a set of front and rears for my b-body. Before I got around to installing them, I put in a set of 1.05 T-bars. Holy Smokes, what a difference in handling with no change in ride quality! I'm not a roadracer, but the car takes the curves faster than I want to go, I never got around to mounting the sway bars.
Re: sway bars, worth it? [Re: RapidRobert] #2578434
11/14/18 04:55 PM
11/14/18 04:55 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I bought a nice, solid 67 383 fact a/c 2 door satellite years ago, and that thing leaned quite a bit on any decent corner. Got a stock 67 gtx sway bar from a friend, added tabs to lower arms, and put urethane bushings on end links too. It helped that nose heavy cruiser.
Re: sway bars, worth it? [Re: BeavisHQV] #2578437
11/14/18 04:58 PM
11/14/18 04:58 PM
Hey you are welcome. Sitting in front of the computer motionless is my favorite activity! On the S/B, there is one for sale for $80 WO the links etc. Just wondering if I should jump on it or not as the complete kit is ~2 bills & I'm sure the extras needed are available seperately.
Re: sway bars, worth it? [Re: RapidRobert] #2578483
11/14/18 06:45 PM
11/14/18 06:45 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
My 318 B body never cam with a bar and it handles just fine.
Re: sway bars, worth it? [Re: RapidRobert] #2578494
11/14/18 07:26 PM
11/14/18 07:26 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I have a BB A-body so it's a tick nose heavy. Added frame connectors and a front and rear sway bar set from Hellwig. I think the car handles quite well for a street cruiser. Lots of fun out on the rural roads.
Re: sway bars, worth it? [Re: buildanother] #2578501
11/14/18 07:46 PM
11/14/18 07:46 PM
Albany, NY
Albany, NY
..ah yup, our '67 Satellite convert is a totally stock 383/2bbl and it rolls like a drunken sailor. laugh2
Re: sway bars, worth it? [Re: 67SATisfaction] #2578516
11/14/18 08:31 PM
11/14/18 08:31 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I bought a 67 Mustang that had the suspension modified with sway bars and lowering springs by the previous owner. That thing cornered dead flat. Spooked a couple passengers by not slowing down for a corner or two like they expected an old car would have to do.
Big bars and moderate springs will give a better ride and still corner well.
Re: sway bars, worth it? [Re: 71birdJ68] #2578538
11/14/18 10:02 PM
11/14/18 10:02 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Compared to what?
Re: sway bars, worth it? [Re: Magnum] #2578546
11/14/18 10:21 PM
11/14/18 10:21 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Compared to what?
Re: sway bars, worth it? [Re: RapidRobert] #2578550
11/14/18 10:30 PM
11/14/18 10:30 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
1970 383 2bbl B-bodies come with 318 T-bars. Never understood the thinking of Ma Mopar on that one.
The broadcast sheet will tell you what's in there.
Re: sway bars, worth it? [Re: RapidRobert] #2578565
11/14/18 11:03 PM
11/14/18 11:03 PM
AndyF Offline
AndyF  Offline
Huge difference between no bar and a peformance bar. There is also a big difference between factory torsion bars and larger bars as well as factory tires and modern tires. All depends on where you want to stop.
I rode in a fairly stock GTX the other day and was surprised at how mushy it was. Been a long time since I was in a stock suspension Mopar so I'd forgotten how soft they are.
Re: sway bars, worth it? [Re: MarkZ] #2578566
11/14/18 11:05 PM
11/14/18 11:05 PM
AndyF Offline
AndyF  Offline
Compared to what?
Need a picture of a pig on ice to fully capture the handling of a B body car with tiny torsion bars, no anti-sway bar and OEM tires!
Re: sway bars, worth it? [Re: AndyF] #2578586
11/15/18 12:10 AM
11/15/18 12:10 AM
The one I got in mind is an Addco #751 & it is 1&1/8". 63 dart convertible I am resurrecting next year. EDIT I remember seeing an early A OE front sway bar & it is very small. (that jogged a memory from the /6 club of America literature decades ago, maybe 7/8"). I will have top notch tires on it.
Page 1 of 3 1 2 3
