A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER #257835
03/18/09 09:54 AM
03/18/09 09:54 AM
DES MOINES IOWA
P
PARTSMAN440 Offline OP
P
DES MOINES IOWA
I need a/c hose routing on left front corner. Does hose go over or thru hole on the tie bar enroute to condenser. Any pictures or info would be helpful.
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: PARTSMAN440] #257836
03/18/09 12:14 PM
03/18/09 12:14 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I cant find a good pic but it goes over the top of the core support
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: PARTSMAN440] #257837
03/18/09 12:20 PM
03/18/09 12:20 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Not sure if this helps - here is the routing on a 70 Charger big block.
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: G_T] #257838
03/18/09 12:23 PM
03/18/09 12:23 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Thats no where near correct, even for 70.
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: AZ_A12_BEE] #257839
03/18/09 12:25 PM
03/18/09 12:25 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I dug thes pic out, Unrestored original 69 Coronet 500 383 4bbl like a Runner
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: AZ_A12_BEE] #257840
03/18/09 12:26 PM
03/18/09 12:26 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
2
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: AZ_A12_BEE] #257841
03/18/09 12:27 PM
03/18/09 12:27 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
3
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: AZ_A12_BEE] #257842
03/18/09 12:28 PM
03/18/09 12:28 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Glad to know that - it's the only reference pic I had from a car show - i took it because I need to know myself . I assume someone boogered up a small block routing then.
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: G_T] #257843
03/18/09 12:44 PM
03/18/09 12:44 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I found some that I had, please save these pics, Its a GTX but the lines are all the same for a big block
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: AZ_A12_BEE] #257844
03/18/09 12:47 PM
03/18/09 12:47 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
other side
Re: A/C HOSE ROUTING FOR BIGBLOCK 69 ROADRUNNER [Re: AZ_A12_BEE] #257845
03/19/09 12:10 PM
03/19/09 12:10 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
Hey AZ_A12 - That's my car-cool-and it IS the correct layout for the A/C. This is an all original car (a few items need to be taken care of). And Partsman, if you need more photos or clarification, PM me.
