Mercedes technology #2578116
11/13/18 10:00 PM
11/13/18 10:00 PM
New York
polyspheric Offline OP
New York
Just watched an assembly video of an AMG V8.
Each piston with rings got about 4 oz. of oil...
Boffin Emeritus
Re: Mercedes technology [Re: polyspheric] #2578198
11/14/18 12:12 AM
11/14/18 12:12 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
4oz. applied where? I used to make them dripping wet years ago, until people smarter than me said not to. Just a smear I'm told now.
Re: Mercedes technology [Re: CMcAllister] #2578207
11/14/18 12:24 AM
11/14/18 12:24 AM
my own world
theraif Offline
theraif  Offline
my own world
thought you were talking this
Re: Mercedes technology [Re: polyspheric] #2578247
11/14/18 03:36 AM
11/14/18 03:36 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
4 oz of oil will not stick to any piston I've seen. 3.5 oz of that oil will drain to the pan. I say it don't really matter how much oil you put on a piston as long as there is some.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Mercedes technology [Re: polyspheric] #2578290
11/14/18 11:04 AM
11/14/18 11:04 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Well there you go - it was seen on the internet therefore it must be true for all applications ................tin foil hat time!!!
Re: Mercedes technology [Re: DoubleD] #2578375
11/14/18 02:18 PM
11/14/18 02:18 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Showing my age, back in the day, oil came in cans. You took a crank type can opener and removed the lid, dipped the piston /rings down in it, pulled it out and installed it. We were not too sophisticated back then, but it worked!
Re: Mercedes technology [Re: Lee446] #2578453
11/14/18 05:39 PM
11/14/18 05:39 PM
Queensland Australia
moparmacka Offline
moparmacka  Offline
Yep, back when I was an apprentice mechanic, I was taught to dunk the entire piston into a container full of engine oil before installing it into the block.
Re: Mercedes technology [Re: polyspheric] #2578583
11/15/18 12:03 AM
11/15/18 12:03 AM
New York
New York
Applied like syrup on waffles
Boffin Emeritus
Re: Mercedes technology [Re: polyspheric] #2578625
11/15/18 02:37 AM
11/15/18 02:37 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
the latest consumer report listed all used Mercedes Benz as cars you do not want to buy because of poor quality.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Mercedes technology [Re: polyspheric] #2578666
11/15/18 10:39 AM
11/15/18 10:39 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
so are you guys telling me I shouldn't dip the assembly in used cat litter after the oil dip ?
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Mercedes technology [Re: ric3xrt] #2578668
11/15/18 11:26 AM
11/15/18 11:26 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I think a lot of guys on here psych themselves out over some of this stuff. Dunking a piston in oil isnt gonna bother ring seal, especially after it mostly drains off. Come on. laugh2
Re: Mercedes technology [Re: Hot 340] #2578777
11/15/18 03:35 PM
11/15/18 03:35 PM
iagree thumbs
I've done that for a lot of years, I do wipe the excess oil off of the skirts and push the rings in and out of the grooves and let the pistons drip into the can of oil while installing one of the others into the bores before installing them thumbs
I also wipe the bores clean several times while assembling the motor and degreeing the cam wrench
Re: Mercedes technology [Re: polyspheric] #2578778
11/15/18 03:35 PM
11/15/18 03:35 PM
New York
New York
This was known to interfere with break-in and leak-down over 20 years ago.
Trust me: when interviewing for the "gunk boy" job at a major race engine builder, the first question on top of the list is chosen to remove as many "you're in the wrong place, Pizza City is next door" as possible.
Question: "How much oil of the same weight as in the pan should coat the rings and lands of an engine being assembled?"
Correct answer: "None, there are better choices".
Boffin Emeritus
Re: Mercedes technology [Re: polyspheric] #2578825
11/15/18 05:01 PM
11/15/18 05:01 PM
Minn
SportF Offline
SportF  Offline
Minn
With every cylinder firing cycle you generate say 1000 degrees of heat and 500 pounds of pressure.
I would think that would be enough heat and pressure to burn and blow any excess oil from the rings in a couple of cycles. After about 5,000 cycles, just about enough time to warm and engine for a couple of "seat the rings" hits, I would think there wouldn't be much "excess" oil in there.
I'm guessing this is like a couple of other topics that show up here, opinions, but no physical proof. There is lots of "this was done, and this happened", but that is not proof.
Re: Mercedes technology [Re: polyspheric] #2578855
11/15/18 06:09 PM
11/15/18 06:09 PM
New York
New York
A cause which produces an effect is not proof? It's the very definition of scientific experimentation.
Boffin Emeritus
Re: Mercedes technology [Re: polyspheric] #2578873
11/15/18 06:50 PM
11/15/18 06:50 PM
Minn
SportF Offline
SportF  Offline
Minn
Poly, your point is well taken. But what I meant was, you put an engine together with lots of oil, no oil. Then what happens, happens. How about the way you started it, flooded, to much timing, too little, what crank oil, how long did it sit...…..what is the cylinder finish, how tight the bore....
Everything that could affect it is thrown in there, there is a lot of possibilities that can change.
What to the "big Three" do? Whatever they do, that is probably what we should do.
Anybody know?
Here is another possibility, it may not matter.
Re: Mercedes technology [Re: polyspheric] #2578890
11/15/18 07:32 PM
11/15/18 07:32 PM
New York
New York
Quite disappointing
Boffin Emeritus
Re: Mercedes technology [Re: polyspheric] #2578892
11/15/18 07:51 PM
11/15/18 07:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I was told by a buddy, who has worked in a serious engine shop for a lot of years, excessive oil in the lands will burn and coke up causing problems with the rings. He told me I was using too much. I never used more than a few short squirts of motor oil on the rings and the skirts, spread evenly by hand, just enough to coat them with a smear. And a squirt in the cylinder evenly spread. Dunk them in a bucket of oil? I can't imagine making such a mess.
And then there's this. When I hear so many different opinions, I always go searching for what the experts have to say.
https://www.youtube.com/watch?v=Z66MXpVKc_0
Re: Mercedes technology [Re: polyspheric] #2578899
11/15/18 08:05 PM
11/15/18 08:05 PM
gregsdart Offline
gregsdart  Offline
Kind of simple, really. A very light coating on all sliding surfaces, just like you find when you would pull a freshly run engine apart. If you have pre oiled the system there is plenty of oil dripping/splshing onto all those parts right away.
Re: Mercedes technology [Re: polyspheric] #2578929
11/15/18 09:09 PM
11/15/18 09:09 PM
New York
New York
If oil distribution is limited to pre-oiling there will be no oil above the oil ring.
Boffin Emeritus
