no controller needed Greg, so doing a Gen 3 Hemi swap, with this valve body ( also available in reverse manual - no trans brake ) in a 518 or A500 is so easy to install. No controller needed, no kick down linkage needed ( cant hook up to drive by wire anyways ) no governor solenoids to go bad, no more overdrive hunting for shifts, overdrive/4th gear now is on the shifter, P N 1 2 3 4
(see video
https://youtu.be/IZcrR2QLXuE)
with a simple linkage change and plug connector this trans brake & reverse manual both with or with out lock up will fit:
A500 518 618 44RH 46RH 47RE 48RE Transmissions
