Mercedes technology
#2578116
11/13/18 10:00 PM
11/13/18 10:00 PM
Posts: 4,206 New York
polyspheric
New York
Just watched an assembly video of an AMG V8. Each piston with rings got about 4 oz. of oil...
Boffin Emeritus
Re: Mercedes technology
[Re: polyspheric]
#2578198
11/14/18 12:12 AM
11/14/18 12:12 AM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
4oz. applied where? I used to make them dripping wet years ago, until people smarter than me said not to. Just a smear I'm told now.
[Re: polyspheric]
#2578247
11/14/18 03:36 AM
11/14/18 03:36 AM
Posts: 4,848 Memphis
HemiRick
Memphis
4 oz of oil will not stick to any piston I've seen. 3.5 oz of that oil will drain to the pan. I say it don't really matter how much oil you put on a piston as long as there is some.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: polyspheric]
#2578625
11/15/18 02:37 AM
11/15/18 02:37 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
the latest consumer report listed all used Mercedes Benz as cars you do not want to buy because of poor quality.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: polyspheric]
#2578666
11/15/18 10:39 AM
11/15/18 10:39 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
so are you guys telling me I shouldn't dip the assembly in used cat litter after the oil dip ?
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: polyspheric]
#2578778
11/15/18 03:35 PM
11/15/18 03:35 PM
polyspheric
New York
This was known to interfere with break-in and leak-down over 20 years ago. Trust me: when interviewing for the "gunk boy" job at a major race engine builder, the first question on top of the list is chosen to remove as many "you're in the wrong place, Pizza City is next door" as possible. Question: "How much oil of the same weight as in the pan should coat the rings and lands of an engine being assembled?" Correct answer: "None, there are better choices".
Boffin Emeritus
[Re: polyspheric]
#2578825
11/15/18 05:01 PM
11/15/18 05:01 PM
Posts: 1,211 Minn
SportF
Minn
With every cylinder firing cycle you generate say 1000 degrees of heat and 500 pounds of pressure.
I would think that would be enough heat and pressure to burn and blow any excess oil from the rings in a couple of cycles. After about 5,000 cycles, just about enough time to warm and engine for a couple of "seat the rings" hits, I would think there wouldn't be much "excess" oil in there.
I'm guessing this is like a couple of other topics that show up here, opinions, but no physical proof. There is lots of "this was done, and this happened", but that is not proof.
[Re: polyspheric]
#2578855
11/15/18 06:09 PM
11/15/18 06:09 PM
polyspheric
New York
A cause which produces an effect is not proof? It's the very definition of scientific experimentation.
Boffin Emeritus
[Re: polyspheric]
#2578873
11/15/18 06:50 PM
11/15/18 06:50 PM
Posts: 1,211 Minn
SportF
Minn
Poly, your point is well taken. But what I meant was, you put an engine together with lots of oil, no oil. Then what happens, happens. How about the way you started it, flooded, to much timing, too little, what crank oil, how long did it sit...…..what is the cylinder finish, how tight the bore....
Everything that could affect it is thrown in there, there is a lot of possibilities that can change.
What to the "big Three" do? Whatever they do, that is probably what we should do.
Anybody know?
Here is another possibility, it may not matter.
[Re: polyspheric]
#2578892
11/15/18 07:51 PM
11/15/18 07:51 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I was told by a buddy, who has worked in a serious engine shop for a lot of years, excessive oil in the lands will burn and coke up causing problems with the rings. He told me I was using too much. I never used more than a few short squirts of motor oil on the rings and the skirts, spread evenly by hand, just enough to coat them with a smear. And a squirt in the cylinder evenly spread. Dunk them in a bucket of oil? I can't imagine making such a mess. And then there's this. When I hear so many different opinions, I always go searching for what the experts have to say. https://www.youtube.com/watch?v=Z66MXpVKc_0
[Re: polyspheric]
#2578899
11/15/18 08:05 PM
11/15/18 08:05 PM
Posts: 9,986 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Kind of simple, really. A very light coating on all sliding surfaces, just like you find when you would pull a freshly run engine apart. If you have pre oiled the system there is plenty of oil dripping/splshing onto all those parts right away.
[Re: polyspheric]
#2578929
11/15/18 09:09 PM
11/15/18 09:09 PM
polyspheric
New York
If oil distribution is limited to pre-oiling there will be no oil above the oil ring.
Boffin Emeritus
[Re: polyspheric]
#2578959
11/15/18 11:00 PM
11/15/18 11:00 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I always dipped the pistons in oil to flood the rist pins, wiped off the excess and sprayed the rings with WD-40, then installed.
[Re: polyspheric]
#2579257
11/16/18 05:57 PM
11/16/18 05:57 PM
gregsdart
If oil distribution is limited to pre-oiling there will be no oil above the oil ring. I lube everything lightly, so there is at least a film on every part like what would be there in a running engine, but will not drown the thing in oil. I can see where many,many,mnay years ago rings and things were crude enough it would be a good idea since they needed a fair amount of break in, but not with todays parts and machine work.
[Re: polyspheric]
#2579537
11/17/18 01:27 PM
11/17/18 01:27 PM
Posts: 1,211 Minn
SportF
Minn
So, Mercedes-Benz, builds thousands upon thousands of engines every year and puts a warranty on them. AND someone thinks the way they put engines together isn't a good idea?
[Re: polyspheric]
#2579567
11/17/18 02:30 PM
11/17/18 02:30 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
What does Mercedes know... hand built naturally aspirated 378 cu in engine 622 hp with a full Warranty spinning to 8000 RPM.
76 Duster
work in progress
