Trans Brake buttons / switches
#2578107
11/13/18 09:50 PM
11/13/18 09:50 PM
Posts: 34,945 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Has anyone ever seen one start not properly working, like sticking ,etc
or , lock car up to where you have to take battery cables off to get one to release or, your R/T's all the sudden start jumping all over ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Trans Brake buttons / switches
[Re: bigdad]
#2578117
11/13/18 10:00 PM
11/13/18 10:00 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
YES! Usually its the wiring in an accordion cord. Had one making my racepack dash wig out and flash one time. Took a while to figure that one out.
[Re: bigdad]
#2578122
11/13/18 10:03 PM
11/13/18 10:03 PM
Posts: 4,647 aotearoa
rebel
aotearoa
You dont have a short in the line somewhere? On my street car i recently had the 2 step misbehave but found it was the line lock switch shorting out.
[Re: Al_Alguire]
#2578124
11/13/18 10:04 PM
11/13/18 10:04 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Ok, well it appears my terminator switch has some internal problems, they are incredibly simple but it seems to be working odd I'll change it , along with the cord , maybe that will get me back on track
[Re: bigdad]
#2578133
11/13/18 10:18 PM
11/13/18 10:18 PM
Al_Alguire
Las Vegas
Well a terminator uses a simple microswitch, easy enough to replace the switch itself
[Re: Al_Alguire]
#2578135
11/13/18 10:24 PM
11/13/18 10:24 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I did , it was doing really weird things stopped most of them but, seems really inaccurate now . would not back up car, would not release .. tested ok too ?
me but, before it went .030 almost every hit, occasionally I would go .010
Now, it does that then next hit .. .100 or .40 red
jumps all over , might be me ..don't think so
[Re: bigdad]
#2578464
11/14/18 05:51 PM
11/14/18 05:51 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Have you charged your battery with the delay box on?
5.53 @ 125 1/8th on the launch control..more left in her!
