hurst 4 speed shifter question 1964 plymouth #2577751
11/13/18 12:52 AM
11/13/18 12:52 AM
IA
64plymouth426 Offline OP
IA
does the hurst shifter knob on a 1964 Plymouth sport fury, 426 st wedge, 4 speed shows the gear pattern and the rest of the knob white? And the 1964 Plymouth sport fury 426 max wedge, hurst shifter knob show gear pattern and the sides of the shifter knob spells hurst?
Re: hurst 4 speed shifter question 1964 plymouth [Re: 64plymouth426] #2577823
11/13/18 06:22 AM
11/13/18 06:22 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes it does to both.Have the OE hurst which is super shifter factory in my 65 which is the same as far as I know.IIRC my parts books show same numbers.Rocky
Chrysler Firepower
Re: hurst 4 speed shifter question 1964 plymouth [Re: 64plymouth426] #2577911
11/13/18 01:51 PM
11/13/18 01:51 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
My '64 Polara BB 4 speed has the original Hurst shifter and the ball shows the shift pattern and is white. The chrome shifter arm has Hurst etched on each side. There is no Hurst lettering on the ball at all.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: hurst 4 speed shifter question 1964 plymouth [Re: 64plymouth426] #2578564
11/14/18 10:58 PM
11/14/18 10:58 PM
AndyF Offline
AndyF  Offline
My '65 Coronet had a black ball with no markings. The shifter handle says Hurst. I suppose someone could've replaced the factory white ball with an aftermarket black one. I never really thought about it much. This four speed has been sitting on a cart in my shop for 30 years. I installed a Doug Nash 5 speed into the car in 1988 so the four speed doesn't have a home.
Re: hurst 4 speed shifter question 1964 plymouth [Re: 64plymouth426] #2578722
11/15/18 01:51 PM
11/15/18 01:51 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
should not say Hurst on the shifter ball. I have an NOS White Ball
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: hurst 4 speed shifter question 1964 plymouth [Re: 64plymouth426] #2578850
11/15/18 06:00 PM
11/15/18 06:00 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Everyone Ive seen has the white ball with pattern.My 65s has had its since i got it in 69.IIRC I still have another ball in the garage.have a pistol grip I swap out with the stick also.Its from a 71 GTX.Just sorry i sold the box for it.Also all early ones had bolt on sticks and comp plus box with stops.Rocky
Chrysler Firepower
Re: hurst 4 speed shifter question 1964 plymouth [Re: AndyF] #2578875
11/15/18 06:51 PM
11/15/18 06:51 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I've got a four speed and shiter just like it and have had it for thirty years. It has a plain black ball also.
Have a great day
Iowan
"obsolete is neat"
Re: hurst 4 speed shifter question 1964 plymouth [Re: Iowan] #2579030
11/16/18 03:11 AM
11/16/18 03:11 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Were those Hurst shifters the type that you had to push the handle down to go into reverse? The Hurst I bought new in 63 was that type.
Re: hurst 4 speed shifter question 1964 plymouth [Re: 64plymouth426] #2579063
11/16/18 09:36 AM
11/16/18 09:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
No they were just super Shifters.Had bolt on handles.They just pulled over and into R.Ill have to see if I can find part numbers in my factory books.But every stock one Ive seen has a white ball and 4 speed pattern.Rocky
Chrysler Firepower
