Front spoilers #2576872
11/10/18 08:18 PM
11/10/18 08:18 PM
N.Y.
sixpacksteve Offline OP
N.Y.
does anyone know if the front spoiler gave any performance difference on or off the track?
Hell Hath No Fury Like Mine
Re: Front spoilers [Re: sixpacksteve] #2576899
11/10/18 09:25 PM
11/10/18 09:25 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
out of all honesty I put one on my car it definitely did not slow it down.. I haven't proven it to be a benefit but then again I believe the car still sits too high I'm looking at having a bumper made with a spoiler Incorporated.. perhaps one that hangs down a little lower..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Front spoilers [Re: sixpacksteve] #2576907
11/10/18 09:41 PM
11/10/18 09:41 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Ask Digby...if the quickest leaf spring car in the world runs one, it must have some benefit.
Re: Front spoilers [Re: sixpacksteve] #2576908
11/10/18 09:42 PM
11/10/18 09:42 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I added a front spoiler to my Dart which definately pulled the front down at speed. Unfortunately it made the back twitchy at 140 mph so i had to add another spoiler on there to fix that. The plus side was, the car was extremely stable & my e.t became very consistant after that.
Re: Front spoilers [Re: sixpacksteve] #2576909
11/10/18 09:43 PM
11/10/18 09:43 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Mine helps the engine run cooler, by creating a lower pressure under the car & pulls hot air out of the engine compartment.
Re: Front spoilers [Re: sixpacksteve] #2576923
11/10/18 10:14 PM
11/10/18 10:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I've added one to my Challenger with the intent of reducing the amount of air being trapped under the front end at speed.
Re: Front spoilers [Re: sixpacksteve] #2576950
11/10/18 11:42 PM
11/10/18 11:42 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Don't know yet but I added one to my blown 68 Barracuda and it just sits barely 3" off the floor. I had to add a 1" board before my ramp flap to keep it from scraping. Anxious to feel the result.
Re: Front spoilers [Re: Blucuda413] #2577046
11/11/18 10:41 AM
11/11/18 10:41 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
Do you have a pic of your set up?
Re: Front spoilers [Re: sixpacksteve] #2577110
11/11/18 02:17 PM
11/11/18 02:17 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
80arrow, the couple of pictures I have does not show up good. I'll try to take some more that will show it better. I used a Ferd I believe it was an Exployer spoiler and shortened it about 6". with just a few holes it bolted up to my glass frontend great.
Re: Front spoilers [Re: sixpacksteve] #2577151
11/11/18 03:44 PM
11/11/18 03:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A cautionary message:
A front spoiler will keep the nose down (and cause oversteer if the car was "balanced" before).
What happens if the car get sideways at speed? The spoiler almost stops working (the frontal area is not the full width of the car, but the shorter diagonal) and the car may may understeer. That's what the big side plates on the rear wing are for - to keep air on the wing.
The better spoilers partially wrap around the nose corners to delay and lessen this effect.
Boffin Emeritus
Re: Front spoilers [Re: polyspheric] #2577191
11/11/18 06:05 PM
11/11/18 06:05 PM
N.Y.
N.Y.
what about e body chin spoilers? astetics only? or the 70 cyclone full
front spoiler?
Re: Front spoilers [Re: sixpacksteve] #2577203
11/11/18 07:06 PM
11/11/18 07:06 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I went looking for a front spoiler for an E body but the only one i found that looked like it would have any effect was that big ugly AAR version. I ended up just fitting the eyebrow tips for asthetics more than anything else.
Re: Front spoilers [Re: rebel] #2577220
11/11/18 07:56 PM
11/11/18 07:56 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
This one is off of a late model Charger. Trims up pretty easily with a utility knife.
Re: Front spoilers [Re: sixpacksteve] #2577237
11/11/18 08:24 PM
11/11/18 08:24 PM
Locomotion Offline
Locomotion  Offline
There was a discussion about late '60's Camaros and their spoiler options in Stock and Super Stock racing. Apparently the spoiler option included the front & rear together. Some were trying to run with only the front spoiler, which wasn't legal. The front spoiler was said to help aerodynamics by keeping some of the air from getting underneath while the rear ducktail spoiler was left off because it caused more drag and slowed the car a bit in a drag racing application.
Re: Front spoilers [Re: Locomotion] #2577241
11/11/18 08:34 PM
11/11/18 08:34 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Absolute fact. Remove the rear spoiler on a Camaro and mph goes up. Front spoiler blocks air from getting under the car and mph goes up. There are also small panels that block air from bypassing the radiator used only on a/c Camaros that also improve mph. I would even go so far as blocking off the back side of the grille completely with clear Plexiglas on a drag race only car and get even better airflow over the car and increase pressure in the area of the cowl induction inlet if I thought it would slip by the inspectors.
Re: Front spoilers [Re: sgcuda] #2577244
11/11/18 08:46 PM
11/11/18 08:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Ok that looks like it has potential. Im not in the US so i need to know if that is a year specific spoiler & a ballpark figure on price would be great. Can you enlighten me please?
Re: Front spoilers [Re: John Brown] #2577246
11/11/18 08:48 PM
11/11/18 08:48 PM
Locomotion Offline
Locomotion  Offline
In class racing, "IF" it would temporarily get by the tech inspectors, it probably wouldn't get past the other racers. That's for circle track and less restricted drag classes..
Re: Front spoilers [Re: polyspheric] #2577304
11/11/18 11:24 PM
11/11/18 11:24 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Thanks for the precaution!! I don't know if my car needs one or not. I just thought it would look neat. I do not run a bumper on my glass front end and it provides an excellent mounting for the spoiler. The ends even wrap around to the beginning of the wheel well. Don't know how it's going to drive yet with the front so low. But even with the low front there is 50/50 wgt distribution. I was concerned about that but it came out nice. I've done a lot of changes in the last couple years, new rear and suspension, removed front suspension and replaced with my K lamb struts and R&P steering with spindle mount wheels. Replaced iron heads with Alum but added a 6-71 blower and FI. Surprisingly it increased my total weight by only 60lbs which is naturally the blower. I just scaled it and the rear has 50.03% of the weight w/driver.
Re: Front spoilers [Re: sixpacksteve] #2577357
11/12/18 12:59 AM
11/12/18 12:59 AM
New York
polyspheric Offline
polyspheric  Offline
New York
I would try to estimate what the "attitude" (nose up, nose down) of the car is at trap speed. Sometimes a high res video from the lights will help, plotted against static attitude. They used to duct tape sticks with stripes painted on them to the fenders vertically - shows how far the suspension sinks.
If the car is nose high at speed a nose dam, spoiler, lip, splitter (extends forward but not down, still helps) will probably help.
Boffin Emeritus
Re: Front spoilers [Re: polyspheric] #2577432
11/12/18 10:36 AM
11/12/18 10:36 AM
N.Y.
N.Y.
if you notice on newer cars they have plastic covers on underside i'm assuming its for aerodynamics. i even thought of shielding the back bumper so it doesn't act as a parachute.
