Windshield gasket sealant what to use? #2577431
11/12/18 10:31 AM
11/12/18 10:31 AM
Guitar Jones Offline OP
I'll be putting the windshield and rear window back in my 92 D250 after fixing the rusted roof and looking for advice as to what to use to seal the gasket around the frame. The area isn't perfect as I had to reuse the header panel from the donor roof. I smoothed it as best as possible using panel bond but I know putting it in without some kind of sealer it's going to leak. So any suggestions and advice will be welcomed. Thanks.
Re: Windshield gasket sealant what to use? [Re: Guitar Jones] #2577465
11/12/18 01:13 PM
11/12/18 01:13 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Does that "new" '92 use the same type of gasket & sealer as my '72 which calls for butyl rubber? That stuff stays sticky for at least 46 years!
https://www.amazon.com/3M-08509-Bedding-Compound-Cartridge/dp/B000PF13JW
Re: Windshield gasket sealant what to use? [Re: Guitar Jones] #2577506
11/12/18 03:05 PM
11/12/18 03:05 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Liquid butyl rubber, be sloppy with it
Angry white pureblood male
Re: Windshield gasket sealant what to use? [Re: Guitar Jones] #2577600
11/12/18 08:19 PM
11/12/18 08:19 PM
Thanks guys.
