70 Cuda Drivers Remote Mirror #2577252
11/11/18 09:07 PM
11/11/18 09:07 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
My drivers side mirror could not be salvaged so I pulled it and will use it as a template to make a new one. Of course if any of you happen to know someone making these, fantastic, I'd love to hear.
My real question is about the cardboard'ish pressed black backer thats between the mirror and the aluminum plate. Whats it for and does anyone make these??
Whats everyone doing about this piece?
Re: 70 Cuda Drivers Remote Mirror [Re: AAR#2] #2577260
11/11/18 09:19 PM
11/11/18 09:19 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Pressed backer?
Got a photo?
Re: 70 Cuda Drivers Remote Mirror [Re: AAR#2] #2577321
11/11/18 11:55 PM
11/11/18 11:55 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Your making your own mirror or did you leave out a number of words?
Re: 70 Cuda Drivers Remote Mirror [Re: AAR#2] #2577373
11/12/18 01:33 AM
11/12/18 01:33 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
NS1AAR
Re: 70 Cuda Drivers Remote Mirror [Re: Morty426] #2577433
11/12/18 10:39 AM
11/12/18 10:39 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Well I was going to use the removed mirror as a template and cut a new mirror, not actually make the mirror.
Re: 70 Cuda Drivers Remote Mirror [Re: ns1aar] #2577434
11/12/18 10:40 AM
11/12/18 10:40 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thanks, that provides an option for the mirror itself, now all I need is the backer
Re: 70 Cuda Drivers Remote Mirror [Re: Alaskan_TA] #2577435
11/12/18 10:46 AM
11/12/18 10:46 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Originally Posted By Alaskan_TA
Pressed backer?
Got a photo?
Here’s what’s left of the backer, this was bonded between the mirror and the aluminum mounting plate.
Also worth noting is that this sort of backer was NOT found on the passenger side
Re: 70 Cuda Drivers Remote Mirror [Re: AAR#2] #2577967
11/13/18 04:17 PM
11/13/18 04:17 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Almost looks like was was just back part of mirror that separated from mirror ?
Re: 70 Cuda Drivers Remote Mirror [Re: AAR#2] #2578292
11/14/18 11:07 AM
11/14/18 11:07 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
So no-one else has ever replaced the drivers side mirror and experienced this formed black paper backer?
Perhaps most simply bond a new glass into the housing and call it a day?
What about the replacement remote side mirrors, does anyone know if they use a backer, use a replacement material, or simply bond it to the housing face?
Re: 70 Cuda Drivers Remote Mirror [Re: AAR#2] #2578343
11/14/18 01:21 PM
11/14/18 01:21 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I think that is there to keep glass cushioned from the cables on the backside. That being said you could go to any Auto parts store and purchase a make your own gasket "mat" that thickness, cut it out and use that...
Re: 70 Cuda Drivers Remote Mirror [Re: QuickBpBp] #2578384
11/14/18 02:41 PM
11/14/18 02:41 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Originally Posted By QuickBpBp
I think that is there to keep glass cushioned from the cables on the back side.
I had that thought as well but the backer has 3 distinct holes cut at the location of the control cable crimped retainers, actually appearing as clearance for them rather than protection.
Agree that I’ll likely make something similar and install it . . . . Just because . . . Since I can’t come to any great reason why it was there in the first place.
Still curious if the replacement assemblies carry this item.
Re: 70 Cuda Drivers Remote Mirror [Re: AAR#2] #2578406
11/14/18 03:26 PM
11/14/18 03:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've completely disassembled many Mopar mirrors for restoration, esp 70 E body, over the decades and have never seen this item...
Re: 70 Cuda Drivers Remote Mirror [Re: DAYCLONA] #2578665
11/15/18 10:36 AM
11/15/18 10:36 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Wow, does that makes mine a 1 of 1 car grin
Well thanks for the feedback, I'll still plan to do a little more investigation and try to figure something out.
