mounting alternatorwith miziere water pump #257717
03/18/09 03:30 AM
03/18/09 03:30 AM
Anonymous OP
Anonymous OP
I BOUGHT A MIZIERE WATER PUMP AND NOTICED THERES NO HOLES TO MOUNT THE ALTERNATOR.I COULDNT FIND ANYTHING SEARCHING AROUND FOR IT ON H=THE WEB. ANY IDEAS OR ANSWERS WOULD BE GREATLY APPRECIATED
Re: mounting alternatorwith miziere water pump #257718
03/18/09 04:18 AM
03/18/09 04:18 AM
Big Chicago
amixon Offline
amixon  Offline
Big Chicago
What type of alternator are you using, race or street car? 440 right? I had a 440 with Indy heads and a CSR water pump and using a Powermater alternator I was able to fabricate a low mount using an adjustable heim joint to brace and adjust the belt tension on the lower part of the alternator,I used a stud in one of the mounting holes for the timing cover near the balancer as the mounting point. I also used the tapped holes in the front of the cylinder head to support the top mount of the alternator and supported that with another adjustable double sided heim joint.
I do not have a picture of the lower mount on anything here in Iraq, but I do have this engine shot that gives you an ideal on what I did. Hope this helps
Big Anthony ANTHONYinIRAQ@gmail.com
1984 B150 Ram Wagon
1978 D100 ClubCab
Re: mounting alternatorwith miziere water pump [Re: amixon] #257719
03/18/09 04:20 AM
03/18/09 04:20 AM
Big Chicago
amixon Offline
amixon  Offline
Big Chicago
Here is a side shot of the same engine...
1984 B150 Ram Wagon
1978 D100 ClubCab
Re: mounting alternatorwith miziere water pump #257720
03/18/09 10:58 AM
03/18/09 10:58 AM
AndyF Offline
AndyF  Offline
Here is one way to do it. This is a bracket that fits behind the water pump and extends out to hold a racing alternator.
Re: mounting alternatorwith miziere water pump #257721
03/18/09 11:12 AM
03/18/09 11:12 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
I use this low mount one from Mancini for a big block. Mounts off the timing cover.
http://us.st12.yimg.com/us.st.yimg.com/I/chucker54_2042_95072505
Re: mounting alternatorwith miziere water pump [Re: cudarex] #257722
03/18/09 12:29 PM
03/18/09 12:29 PM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
Thats what I used, worked fine.
Looks nice and easy to work on the motor with it down out of the way!
Ed
Re: mounting alternatorwith miziere water pump [Re: AndyF] #257723
03/18/09 12:43 PM
03/18/09 12:43 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Andy,
How many amps is that racing alt.?
I'm guessing it's for race only and
not enough amps for a street/strip car.
Snap your neck, mega G-force launch, is all I want!
Re: mounting alternatorwith miziere water pump [Re: BDS871Cuda] #257724
03/18/09 02:16 PM
03/18/09 02:16 PM
AndyF Offline
AndyF  Offline
That small alternator is 55 amps. Works fine on a street/strip car as long as you don't go crazy with the electronics. Lots of production cars came with less than 55 amps.
Re: mounting alternatorwith miziere water pump [Re: AndyF] #257725
03/19/09 01:31 PM
03/19/09 01:31 PM
Big Chicago
amixon Offline
amixon  Offline
Big Chicago
Andy, you are like the Batman of the Mopar world, where DO you get all of those cool toys?
With just a few tweaks it looks like you could fit a bigger alternator in there...
1984 B150 Ram Wagon
1978 D100 ClubCab
Re: mounting alternatorwith miziere water pump [Re: amixon] #257726
03/19/09 02:18 PM
03/19/09 02:18 PM
AndyF Offline
AndyF  Offline
I just invent them and make them!
