Re: Hurst V Gate shifter fitment
[Re: Porter67]
#2577034
11/11/18 06:47 AM
11/11/18 06:47 AM
Posts: 608 TN
1DGEMAN
TN
Way back in the day I put a Mr Gasket V Gate shifter in my Duster. It requires a lot of cutting of the tunnel. A better choice is the Hurst Ram Rod shifter much more compact and it shifted better. I still have both of those shifters. I may end up installing one in one of my projects. The Long shifter is the best out there. I used their T handle shifter on my Jericos until they came out with the Pistol grip.
Real Men shift for themselves
[Re: MadMopars]
#2577039
11/11/18 10:04 AM
11/11/18 10:04 AM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
I loved the one I had and drove it on the street for several years, but you do have to cut a large chunk out of the rear section of the 4 speed hump.
[Re: MadMopars]
#2577051
11/11/18 10:58 AM
11/11/18 10:58 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
if you put an A833 in your D300 it'll work nicely and put the shifter in a nice spot compared to the stock OD 4 speed shifter.
of the 17 or so Big block D100/150s I built over the years 10 of them had a V gates in them, it was the best way to deal with the awkward location of the shifter with an A833.
On your 74 RR it'll put the handle about 3 inches behind the front edge of the seat,.....but you'll thrash the floor hump....forget any console The only A body I've had a V gate in was a 70 Duster, I used a 69 B-body trans with a Modified trans cross member and fabed up a floor hump to work.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: MadMopars]
#2577171
11/11/18 04:51 PM
11/11/18 04:51 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Step one....... cut giant hole.
I had bought one to use with a liberty pro-shifted 833......... but I just couldn’t bring myself to cutting my totally rust free factory 4 speed floor.
So, I sold it....... along with the trans.
[Re: MadMopars]
#2577177
11/11/18 05:20 PM
11/11/18 05:20 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I would say the Mr. Gasket and Long are basically the same. I have one in my Barracuda and think it is a great drag race shifter but using it on the street in my opinion would be a real pain. Then of coarse the cutting to fit, thats up to you.
[Re: MadMopars]
#2578007
11/13/18 06:09 PM
11/13/18 06:09 PM
Posts: 4,457 Washington
madscientist
Washington
Have you look at the Hurst Super Shifter 3? If not you might want to before buying any new shifter I saw a couple of those guys on eBay but if I'm not mistaken, those are an "H" pattern shifter correct? I was thinking I wanted to go with an "Inline" shift pattern setup this time around which is why I was looking at the V gate and RamRod option. Also, I'm thinking I'm going to dabble with nitrous on the Road Runner so I feel like it will be a pretty busy and stressful ride at times as a rookie. Is that Super Shifter 3 a pretty slick setup? I've used several SSIII's and there's one in my car now. It's not the shifter that makes the driver. The SSIII is a good shifter if you can find one. IIRC, the Super Shifter and the Super Shifter III are exactly the same except the III has a reverse lockout. I've also use V-Gate shifters on the street. The only thing wrong with the V-Gate is you have to cut what I consider to be a massive hole in the floor and I hate that. Also, everybody who has one wants straight gold for them. The V-Gate is easy to drive on the street. The SSIII is about as good as it gets for a race shifter that has an H gate.
[Re: MadMopars]
#2578008
11/13/18 06:11 PM
11/13/18 06:11 PM
madscientist
Washington
Just found a refurbished SSIII for 400 bucks on eBay. Damn. I don't think mine was that much new.
[Re: MadMopars]
#2578089
11/13/18 09:06 PM
11/13/18 09:06 PM
fast68plymouth
So. Burlington, Vt.
I remember being in the staging lanes at the track one time and there was a guy chatting with the owner of this 69 a12 4 speed car that was running high tens. I don’t recall what the question was, but the answer was, “I’ve broken everything you can break from the block rearward......and a few things more than once”.
That’s the thought that comes to mind when I think: heavy car, 833, nitrous.
