Engine date code #2573963
11/04/18 05:06 PM
11/04/18 05:06 PM
ontario canada kingston
aspenrt360 Offline OP
Hey guys working on a car i picked up for my wife, it's a 72 340 Demon was an export car as i was pulling it apart i noticed a large difference between the build date and the casting date on the block and just assumed it was an engine swap car. today i am out in the shop with a buddy and we got to looking at the vin# and it matches the car! the block is a 1-15-71 and the cart is 4-72 this is a big stretch to me is this possible? or likely? the other thing i find odd is the pistons are 4 valve relief and look to be low comp which does not work with a 1-15-71 block but could very well be for a 4-72 340. is it crazy to think they had blocks kicking around that long before they assembled them? any insight would be great.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Engine date code [Re: aspenrt360] #2573990
11/04/18 05:54 PM
11/04/18 05:54 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
no "first in / first out" inventory controls were used
if a block or pallet of blocks got buried, whenever they were rediscovered they'd be sent into further production
from what I've seen, '72 was an odd year with many big variations date-wise, maybe new procedures being put to use, cleaning up former messes shruggy
the block casting has not much to do with the final assembly, what is stamped on the front of the block below the driver's side head?
HM340R xxxx xxxx ?? scope cast crankshaft ??
Re: Engine date code [Re: aspenrt360] #2573994
11/04/18 05:56 PM
11/04/18 05:56 PM
AndyF Offline
AndyF  Offline
Mopar during that period of time was just lucky to keep the production lines running. They were almost broke and had lots of quality issues so I doubt they paid much attention to inventory control. It wasn't run like a Toyota factory.
Re: Engine date code [Re: 6bblgt] #2573995
11/04/18 05:57 PM
11/04/18 05:57 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
can you share the fender tag info? VON = E3xxxx ?? scope
Re: Engine date code [Re: 6bblgt] #2574005
11/04/18 06:18 PM
11/04/18 06:18 PM
What part are you looking for?LM29H2B or the sequence #
Re: Engine date code [Re: aspenrt360] #2574008
11/04/18 06:33 PM
11/04/18 06:33 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
any info you are willing to share, to help answer your questions
if the Demon still has its original door sticker - it will show when the car was actually completed: MDH (MonthMonth DayDay HourHour)
the engine number, below the head, will show when the engine was assembled
if it was an EXPORT ordered car & delivered NEW "stateside" the VON will be "E3xxxx"
or was it an order originated in Canada?
Re: Engine date code [Re: aspenrt360] #2574018
11/04/18 06:46 PM
11/04/18 06:46 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What Dan said plus;
It wasn't just block castings that sat around for long periods of time, complete engine assemblies also got used long after their assembly dates. I wouldn't say it was the "norm" but it definitely happened.
Re: Engine date code [Re: aspenrt360] #2574019
11/04/18 06:46 PM
11/04/18 06:46 PM
front of block under drivers head is M H 340 P 38118062
Re: Engine date code [Re: aspenrt360] #2574021
11/04/18 06:48 PM
11/04/18 06:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
M = Mound Road Engine Plant
H = 1972 Model Year
340 = CID
P = Premium fuel
Day 3811 Assembly date is Monday, January 3, 1972
The rest is the build sequence
Re: Engine date code [Re: aspenrt360] #2574023
11/04/18 06:52 PM
11/04/18 06:52 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
M H 340 P 38118062
M = Mound Rd DETROIT, MI engine assembly plant
H = 1972 model year
340 = cu.in.
P = premium fuel (is this clear? low compression '72s are usually R = regular fuel ?)
3811 = Mon. 1/3/72 (is this clear? 1st cast crank was scheduled for 3911, Wed. 4/12/72)
8062 = 62nd cast crank 340 assembled
Re: Engine date code [Re: aspenrt360] #2574030
11/04/18 07:07 PM
11/04/18 07:07 PM
it is a P. this motor has been toyed with for sure as it has a forged crank but cast pistons the odd thing is the bearings are date coded 71 the timing chain is dated 83 so someone was in there. as for some of the other stuff this was an export car it has an odd euro serial# plate on the fender well and it has the I on the fender tag and the story is that a service man brought it back from Germany.
Re: Engine date code [Re: aspenrt360] #2574044
11/04/18 07:47 PM
11/04/18 07:47 PM
Thanks for the info so far Gents!
Re: Engine date code [Re: 6bblgt] #2574046
11/04/18 07:51 PM
11/04/18 07:51 PM
I will recheck the 3811 part it is a bit tough to see. probably get back on here tomorrow.
Re: Engine date code [Re: aspenrt360] #2574516
11/05/18 06:20 PM
11/05/18 06:20 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
popcorn
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Engine date code [Re: 6bblgt] #2576791
11/10/18 03:04 PM
11/10/18 03:04 PM
So while putting the engine in today i checked the Von it is E35229 i have no idea what that stands for?
Re: Engine date code [Re: 6bblgt] #2576794
11/10/18 03:07 PM
11/10/18 03:07 PM
I also have the door sticker on the door still i would post a pic with the last couple of # blocked but i have not posted a pic on here in 10 years!
Re: Engine date code [Re: aspenrt360] #2576839
11/10/18 06:32 PM
11/10/18 06:32 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I believe the E3xxxx VON indicates it was ordered from over-seas & scheduled for delivery stateside when new - the serviceman's plans & the car's delivery status could've changed or it was shipped to Germany at a later date
did you get a good look at the assembly date? 3811 VS. 3911 scope
Re: Engine date code [Re: aspenrt360] #2576847
11/10/18 07:22 PM
11/10/18 07:22 PM
i will check the date and try to post some pics tonight.
Re: Engine date code [Re: aspenrt360] #2576863
11/10/18 07:58 PM
11/10/18 07:58 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
popcorn popcorn
Re: Engine date code [Re: aspenrt360] #2576880
11/10/18 08:50 PM
11/10/18 08:50 PM
Ok so on the front of the block for sure MH 340 R 3911862 was really hard to read so i sanded off the paint and used a sharpie to get some definition the bottom of the r is faint but it is there and so is the 9 instead of the 8 so that seems to make more sense.
