Re: 68 Barracuda Slant 6 flywheel interchange?
[Re: Pale_Roader]
#2576589
11/10/18 12:05 AM
11/10/18 12:05 AM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Car Slant uses a 122 tooth flywheel. The biggest clutch it will take is a 10". 130 tooth flywheel will not fit in the bellhousing.
I had an adapter plate made so I could use a 130 t flywheel and small block bellhousing, but I sold it years ago.
[Re: Pale_Roader]
#2576621
11/10/18 01:12 AM
11/10/18 01:12 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
All of the NP833 trannys I've seen all have the same bolt pattern to the bell housings, all the way from 1964 to 1980 or later on the O.D. NP833 cases Sorry to be the bearer of bad news He will need to find a bellhousing for a 10.5 inch clutch and a 130 tooth flywheel for the slant six motor to use your clutch kit
[Re: Pale_Roader]
#2576640
11/10/18 01:55 AM
11/10/18 01:55 AM
slantzilla
Park Forest, IL
Trucks used the "HD" 10" clutch with an 833. The bigger clutches used a really funky bellhousing that will neither fit in a car nor accept an 833.
