Page 1 of 3 1 2 3
CalTracs setup - Chassis separation or limit it? #2575519
11/07/18 08:28 PM
11/07/18 08:28 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I know when Calvert first came out with CalTracs years ago, he was recommending stiff multi-leaf springs with minimal arch and stiff shocks to keep the chassis separation to a minimum ("Wasted motion").
However, most of the pics I see these days of leaf-spring Stock Eliminator cars that are using CalTracs or Assassin Bars w/ similar ETs as my car show quite a bit of separation... almost as much as you'd see from the old SS springs or slapper bars setups.
I'm all ears here, folks.
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2575531
11/07/18 08:55 PM
11/07/18 08:55 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Not sure if this is what you are looking for. I am not super fast, 1.41-1.45 60.ft. This pass was 1.43 10.35
https://youtu.be/rYA-Ipb1GWE
Re: CalTracs setup - Chassis separation or limit it? [Re: nss guy] #2575533
11/07/18 09:06 PM
11/07/18 09:06 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
That looks Great to me !!!!!
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2575549
11/07/18 09:47 PM
11/07/18 09:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Cal Track by nature of it's instant center location will always separate. The trick is controlling the speed of that separation with shock rebound.
Doug
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2575599
11/07/18 11:28 PM
11/07/18 11:28 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Short front segment compared to GM cars. Always going to hit the tire hard. You need a good shock to control it all...
Dont you have a post that you want a "cheap" shock ?
Smh..lmfao !
....BAD A$$ STREET CAR.....
Re: CalTracs setup - Chassis separation or limit it? [Re: n20mstr] #2575641
11/08/18 12:14 AM
11/08/18 12:14 AM
BradH Offline OP
BradH  Offline OP
Tony - Not sure what "smh" means, but I'll take a guess it means you think I'm an idjit. shruggy
EDIT: I already have "cheap" shocks. What I asked in the other post is recommendations for a reasonable and -- yes, affordable -- upgrade from what I have now.
Re: CalTracs setup - Chassis separation or limit it? [Re: nss guy] #2575659
11/08/18 12:45 AM
11/08/18 12:45 AM
BradH Offline OP
BradH  Offline OP
Your times are very close to mine, so it's a good comparison. Are those CalTrac (Rancho) 9-way adjustables?
Did you notice your slicks try to unload shortly after the hit? See if you can slo-mo starting about the :58 mark. At least that's what I think I'm seeing.
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2575667
11/08/18 12:52 AM
11/08/18 12:52 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I saw the same thing
68 Barracuda Formula S 340
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2575668
11/08/18 01:04 AM
11/08/18 01:04 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Shaking My Head.
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2575696
11/08/18 02:17 AM
11/08/18 02:17 AM
N
N
Not at all, just giving you a hard time.....lol
If I thought someone was an idiot, I wouldn't reply
My sons duster has cal tracks with their split mono. He's got Afco double adj in the rear. They have to be quite stiff to control the hit, and he's been 1.45 10.99 . Honestly I think he needs more shock at this point. Look at this way , it's cheaper in the long run to buy santuff a or big gun Afros once, than buying Viking ,strange, or reg afcos.
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2575903
11/08/18 03:04 PM
11/08/18 03:04 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Maybe Shiloh (White Dart) will chime in. His car works great and hauls the mail.
My Roadrunner runs 10.90's (Heavy POS) hits the tires hard (4-speed) and I control everything with the shocks.
Re: CalTracs setup - Chassis separation or limit it? [Re: nss guy] #2575937
11/08/18 04:00 PM
11/08/18 04:00 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I had my sliders where yours are.If you watch the slider it maxes out at the hit almost inloading the tire.I moved the slider so that it is 80/20.
I want a go-pro for Christmas!!!!!
Also,I went Viking with the stiffer valving for the rear.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2576034
11/08/18 08:00 PM
11/08/18 08:00 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I think the shocks needed tightened up, I had them probably 3-4 clicks from full tight. A couple of runs later I tightened them up and improved 60ft. Made 3 10.19 passes in a row after tightening them up.
Re: CalTracs setup - Chassis separation or limit it? [Re: nss guy] #2576080
11/08/18 10:07 PM
11/08/18 10:07 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
The key is to keep the tire planted.. controlling the rate of separation is Paramount.. you don't want to drive the tire into the ground
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2576219
11/09/18 03:58 AM
11/09/18 03:58 AM
gregsdart Offline
gregsdart  Offline
Look at how rise in the rear of a drag car gets less and less the faster the car gets.
As acceleration decreases in a slower car, controled seperation keeps the tire loaded enough for good traction. Once you get enough weight and g force planting those tires to get the front off the ground, you don't need any. It takes virtually no seperation and about eight inches of forward travel in my dart to get there. My carhas the power to keep the tires planted very early. A high 10 sec car not as much. Every car and situation will vary.
Re: CalTracs setup - Chassis separation or limit it? [Re: gregsdart] #2576295
11/09/18 12:56 PM
11/09/18 12:56 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I agree with Greg, there are big differences between a 2800lb 8sec car that scales well and a nose heavy 3800lb 12 sec car.
"Just a Bracket car dressed up like a streetcar"
Re: CalTracs setup - Chassis separation or limit it? [Re: Just-a-dart] #2576372
11/09/18 02:58 PM
11/09/18 02:58 PM
BradH Offline OP
BradH  Offline OP
In my case, it's a low-to-mid 10-sec 3800# nose-heavy car. whistling
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2576465
11/09/18 05:44 PM
11/09/18 05:44 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Brad that comment was not pointed at you.
If I was buying shocks for your car I would buy probably buy double adjustable AFCOs.
Re: CalTracs setup - Chassis separation or limit it? [Re: BradH] #2576472
11/09/18 05:52 PM
11/09/18 05:52 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
My best 60ft has been a 1.33. It is always in the low 1.30's and I am using Rancho 9 ways on the back. I am using home made caltracs with stock leaf springs and shackles. I am running Drag Radial tires.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: CalTracs setup - Chassis separation or limit it? [Re: Just-a-dart] #2576486
11/09/18 06:32 PM
11/09/18 06:32 PM
BradH Offline OP
BradH  Offline OP
I didn't take it as an insult; I just wanted to add some context on what I am (or, should be) running.
Found this article that I think is applicable to my original question: https://www.racepagesdigital.com/extensi...feet-at-a-time/
Page 1 of 3 1 2 3
