Re: 75 Dodge D300 Engine Mount Question B/RB
[Re: MadMopars]
#2576089
11/08/18 10:32 PM
11/08/18 10:32 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
The passenger side is currently on the backside of the engine boss and I'm thinking it needs to be moved to the front. Wouldn't moving the bracket to the front of the boss move the motor further to the rear? Something sure sounds wrong. may the brackets aren't right? can you post some pictures?
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2576099
11/08/18 10:51 PM
11/08/18 10:51 PM
Posts: 1,292 Tucson AZ,
MadMopars
Tucson AZ,
[Re: MadMopars]
#2576109
11/08/18 11:16 PM
11/08/18 11:16 PM
bboogieart
Lost and Spaced
Not sure what set-up that is, but you simply cannot move the bracket to the front as the lugs are different sizes. My guess... that is so the bracket can only be installed one way. Might be your brackets are wrong as mentioned above.
[Re: bboogieart]
#2576116
11/08/18 11:26 PM
11/08/18 11:26 PM
Posts: 4,918 Wills Point, Texas
Hugh Jorgan
Wills Point, Texas
The brackets look correct. Maybe look to see if there's another hole in the frame (where the biscuit bolts in)
It's hard to see in your pics, but are your brackets slotted (like the ebay set) where the biscuit bolts to them?
[Re: MadMopars]
#2576157
11/09/18 01:26 AM
11/09/18 01:26 AM
RapidRobert
Just thinking out loud but is it possible that something ain't right on the trans mt end that is pulling the eng/trans (& the rubber showing) rearward?
[Re: Hugh Jorgan]
#2576165
11/09/18 01:38 AM
11/09/18 01:38 AM
MadMopars
Tucson AZ,
It's hard to see in your pics, but are your brackets slotted (like the ebay set) where the biscuit bolts to them? There doesn't look to be any other holes in the frame. My engine mounts are slotted like the ones on eBay though.
[Re: RapidRobert]
#2576167
11/09/18 01:44 AM
11/09/18 01:44 AM
MadMopars
Tucson AZ,
Just thinking out loud but is it possible that something ain't right on the trans mt end that is pulling the eng/trans (& the rubber showing) rearward? I'll take a look tomorrow. I remember when I replaced the mounts years ago, (10+ years) I fought the transmission mount and passenger engine mount for a bit trying to line everything up better. Obviously it's been ok for years but, since I'm swapping the motor now I figured it's as good a time as any to try to make it as good as I can. I'll update you when I get time to put eyes on it again. Thanks for the input guys. Much appreciated. -Trent
