Re: Replacing oil pump in 360
[Re: 69 Road Chicken]
#257604
03/17/09 11:21 PM
03/17/09 11:21 PM
RapidRobert
As said I would check it with another mechanical gauge 1st. get a new std pump, open it up & rinse it out/lube it w your eng oil & bolt it up with it held solidly up in the rear cap as you tighten the bolts & dont use the gasket that comes with it.
[Re: CJK440]
#257609
03/18/09 10:23 AM
03/18/09 10:23 AM
The quality of the pumps has gone down lately, IMHO. I have seen cover clearances of over .005 and machining on the bottom out of flat by .003. The last one I tested was a high volume that flowed less than an old factory standard flow pump.
As was said, confirm the pressure, check the plugs and such, and definitely measure the clearances on a new pump if you change it out.
