Bang-for-the-buck rear damper upgrade over Ranchos? #2575514
11/07/18 08:20 PM
11/07/18 08:20 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Yeah, I know... every time someone posts a "What shocks (dampers) should I buy?" question, the basic answers are "Buy the best you can afford" and "AFCO, Santhuff, Menscer-modified..."
Let's try this a different way. I really shouldn't be buying any new dampers at all, so the "best I can afford" answer should probably be about $10 (for the pair). However, I believe the old 5-way Ranchos on the rear of my Challenger leave a lot of room for improvement.
Given that, what would people recommend as a bang-for-the-buck rear damper upgrade? 3750+# BB E-body on 275 drag radials, has run a best of 1.45 60-ft w/ CalTracs & monos, engine upgrade picked up 50-ish HP and 30-ish torque over what pushed the car to 10.5s at 126 before.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575534
11/07/18 09:09 PM
11/07/18 09:09 PM
gregsdart Offline
gregsdart  Offline
How much leverage does the caltrac setup have compared to other suspensions? I look at the SLR times the torque times 2 for converter multiplication and the answer in torque trying to twist the rear housing into the ground is unreal at the hit, where you need the control. Distance from instant center to the shock in feet divided into that answer is some kind of an indication of what you are dealing with. My car: 760 tq x2 x11.17slr = 17,000 ft lbs รท 2.75 ft= 6200 ft lbs of pull on both shocks at the hit. All this blah blah doesn't give you much of an answer, but maybe will help you figure out what you really need back there. I am on my third upgrade (or fourth? I forget) on rear shocks. I now have Afco big guns, and they may not be valved stiff enough.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575541
11/07/18 09:31 PM
11/07/18 09:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Bang for the buck? AFCO Big Guns.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575563
11/07/18 10:27 PM
11/07/18 10:27 PM
AndyF Offline
AndyF  Offline
I wouldn't buy anything new until I proved that my existing shocks couldn't get the job done. A little time at the track shooting some video might answer the question. You have adjustable shocks now so it would be fairly easy to adjust them full soft and full hard and see how the car reacts. Then send the video to Calvert and see what they say.
The new Calvert shocks are 9 way adjustable so maybe that is all you need. Or perhaps they have tighter or looser shocks depending on what you need.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575574
11/07/18 11:04 PM
11/07/18 11:04 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
What's it doing? Separating excessively? Crushing the tire? Wind the shock up tight and see if it controls the housing.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575577
11/07/18 11:07 PM
11/07/18 11:07 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Really ? There is no cheap way to go fast ...lol
poor Monte, he would have a field day with this. Put it in perspective, santuffs might be 1200.00 ? Would it be worth it to save 4-600 ? And not go as fast as you could ?
a radial needs a good double adj to work well, skimp somewhere else.
....BAD A$$ STREET CAR.....
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575578
11/07/18 11:07 PM
11/07/18 11:07 PM
Washington
madscientist Offline
Washington
You need a double adjustable shock. There is no reason a Viking DA won't do everything you need it to do for reasonable money.
I will never understand a single adjustable shock. There is no way that a shock that changes bump and rebound with the same knob at the same time can accomplish the control you need.
Bump and rebound need to be seperate.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575604
11/07/18 11:33 PM
11/07/18 11:33 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
if meaning budget - go Viking DA's . They work , I had Rancho's . They wouldn't cut it when I went 505ci .
Just decide are you going radial or crossply tyre and choose appropriately
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: tex013] #2575650
11/08/18 12:32 AM
11/08/18 12:32 AM
BradH Offline OP
BradH  Offline OP
Yeah, I need a DA damper, even for my P O S street car. But it's still tough to justify the cost of the high-end stuff for what it is.
Tony - Monte would say the same thing he always said, which is what I inferred in my original post. Feel free to take his position on the subject and carry on the tradition. wink
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: CMcAllister] #2575652
11/08/18 12:36 AM
11/08/18 12:36 AM
BradH Offline OP
BradH  Offline OP
Won't know until it makes it back to the track. Just looking for options, since I expect an upgrade is in my future.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575655
11/08/18 12:43 AM
11/08/18 12:43 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have been happy with my Viking DAs on the rear of my car. I still need to get some things under control but I have plenty of adjustment left.
68 Barracuda Formula S 340
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575695
11/08/18 02:13 AM
11/08/18 02:13 AM
N
N
Strang or atco, I'd lean towards the Afco. They are reasonable and still work well.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2575875
11/08/18 02:27 PM
11/08/18 02:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Here's what I know first hand on my junk; Bottom hole on the 25" ft. segment, 5-way Ranchos on 4 or 5 and 90-10's in the ft........1.33-1.34 60's........Mow I have Shilo's DA rear Vikings and first and last time out about 2' of air and a 1.34 on crappy Hoosier QTP's........ beer
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: n20mstr] #2576376
11/09/18 03:02 PM
11/09/18 03:02 PM
BradH Offline OP
BradH  Offline OP
I see AFCO has a standard-fitment Eliminator DA series, but the Big Guns listed are all much shorter and not for that type of application. shruggy
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2576397
11/09/18 03:33 PM
11/09/18 03:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have Shilos DA Viking front coil overs that I WAS going to use but decided against it so not sure if they would work in the rear or not as just a shock........15" extended and 10 1/2 compressed......... thumbs
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2576437
11/09/18 04:51 PM
11/09/18 04:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Call and talk to them. I know from experience, the difference between standard and BG valving is substantial. Or just call Menser. His stuff is not that much more money.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: CMcAllister] #2576471
11/09/18 05:50 PM
11/09/18 05:50 PM
N
N
X2 call Menser. Dealing with guys like that are another lesson I have learned. The service/support after the sale is worth every penny you pay them up front.
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: n20mstr] #2576487
11/09/18 06:36 PM
11/09/18 06:36 PM
BradH Offline OP
BradH  Offline OP
Lots of stuff about Menscer online, but I haven't seen much about prices listed. I'm guessing... $800-1000 for a pair of basic modified AFCO DA "twin tube" dampers?
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: BradH] #2576488
11/09/18 06:38 PM
11/09/18 06:38 PM
N
N
or call Mike Roth @ MR2 , hes famous for building SS/AH cars, but he is a dealer for Santuff and builds stockers also. Another good source of what will work well on your car. I bought my Santuffs from him
Re: Bang-for-the-buck rear damper upgrade over Ranchos? [Re: n20mstr] #2576491
11/09/18 06:42 PM
11/09/18 06:42 PM
BradH Offline OP
BradH  Offline OP
I've seen pics of some cars Roth's built. drool
Tony - Mind if I swipe your signature and modify it for my own?
"... SLOW-A$$ STREET CAR... even when it's actually running "
laugh2
