Re: V10 to V8 swap
[Re: nd65]
#2575521
11/07/18 08:36 PM
11/07/18 08:36 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The trans will have to be changed. V10 units use the diesel bellhousing pattern.
Re: V10 to V8 swap
[Re: nd65]
#2575852
11/08/18 01:38 PM
11/08/18 01:38 PM
Posts: 4,573 Motor City
6PKRTSE
Motor City
As long as you have everything from the donor truck as mentioned, all of the connectors, harnesses, computer etc. It should be a doable swap but not easy work. Looking at my V10 it looks like the cab would have to come off of the frame in order to get the engine out but maybe not, without the core support it may go far enough forward to clear windshield & firewall.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: V10 to V8 swap
[Re: nd65]
#2576148
11/09/18 01:01 AM
11/09/18 01:01 AM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I wish you were closer I'd buy that truck and swap a Cummins into it. That's what a lot of people do. The Cummins outlasts the body and no one can afford the gas for a V10 truck, so they are in good shape and have all the HD stuff on them. I think you'd be better off selling it to a Cummins guy.
Sheldon
Re: V10 to V8 swap
[Re: QuickDodge]
#2576707
11/10/18 11:10 AM
11/10/18 11:10 AM
Posts: 5,964 Greenville, PA
redraptor
Greenville, PA
Could a used oil pump housing be utilized? Somebody somewhere has the fix for this. Considering it was based off the magnum v-8 I find it hard to believe the oil pump housing is unique to that engine.
Re: V10 to V8 swap
[Re: nd65]
#2577013
11/11/18 03:22 AM
11/11/18 03:22 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Like a Buick it's part of the timing cover iirc.
Re: V10 to V8 swap
[Re: nd65]
#2577387
11/12/18 02:33 AM
11/12/18 02:33 AM
Posts: 954 garnett kansas
rhad
garnett kansas
if the pump is really like a buick pump there MIGHT be a repair kit ,buick had one that used thicker gears and a spacer and different cover,it came with thin brass shims to use when gettin the gears setup correctly might be worth lookin into if there are no aftermarket covers available,have you checked the guy in arizona that sells discontinued nos parts? cant think of his exact name,but try google arizona parts,it should pop up
my ladder of success is missing some rungs
