What to do with "rusty" headers? #257545
03/17/09 09:33 PM
03/17/09 09:33 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I have my motor out and my headers are a little "rusty". What is the best way to go about treating them and preserving them to get the most "mileage" out of them?
Thanks,
Re: What to do with "rusty" headers? [Re: 1fastrunner] #257546
03/17/09 09:42 PM
03/17/09 09:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bead blast them, then use Eastwood's stainless steel exhaust paint on them or have them coated with one of the jet-hot-type coatings. Paint or coat them as soon as you can after getting them clean. I've done this a couple of times with good results.
Re: What to do with "rusty" headers? [Re: topside] #257547
03/17/09 09:56 PM
03/17/09 09:56 PM
But, I have no way to bead blast them. Any other ideas?
Re: What to do with "rusty" headers? [Re: 1fastrunner] #257548
03/17/09 11:11 PM
03/17/09 11:11 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Backyard treatment: give them a good once over with some rough sandpaper to knock the heavy rust down, then coat them with OSPHO to completely get rid of the rust. From there, you can try to paint or coat them with some header paint. but it probobly won't last. At least with the ospho treatment, you'll stop the rust.
Re: What to do with "rusty" headers? [Re: StealthWedge67] #257549
03/17/09 11:16 PM
03/17/09 11:16 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I took mine to a local body shop,he blasted them for $20.00. Then hit them with the Eastwood stuff(couple coats),been there 3 yrs and still look pretty good!
Re: What to do with "rusty" headers? [Re: Dcuda69] #257550
03/18/09 01:53 PM
03/18/09 01:53 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
It is time consuming, but you can hand sand them. If you can find a place that will sandblast them, you will get better results. My vote is for VHT High Temp paint, really tough stuff for spray bomb header paint! The pic is my 340, the headers were used, I sandblasted and painted them with the VHT.
Re: What to do with "rusty" headers? [Re: 4BBodies] #257551
03/18/09 01:56 PM
03/18/09 01:56 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Oh, the pic is back in August, it has been running for a few months now, and they headers still look the same.
Re: What to do with "rusty" headers? [Re: 4BBodies] #257552
03/18/09 03:56 PM
03/18/09 03:56 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
Investigate Jet-Hot Coatings. You might want to talk to them. They coat both inside and out. Lowers heat in the cabin. The attachment is of headers that are 10 years old. I know of no other treatment that lasts as long as these have for me.
Re: What to do with "rusty" headers? [Re: BELVEDERE67] #257553
03/18/09 11:38 PM
03/18/09 11:38 PM
MA
440beeper Offline
440beeper  Offline
MA
check out a local restoration shop...they will usually blast your headers for a reasonable fee. Paint it with an Eastwood coating and you're done. Special coatings like JetHot probably last longer, but Eastwood coatings work pretty well for the money.
Re: What to do with "rusty" headers? [Re: BELVEDERE67] #257554
03/19/09 01:15 AM
03/19/09 01:15 AM
Chilly Northern, Minn.
71 Charger R/T Offline
I agree with Belvedere67, Jet-Hot inside and out. They will last a loooong time and look good as well. My brother-in-law did this on advice of a gentleman with experience with it who also said "you don't need to buy expensive headers, get some cheapies with good flow and they'll last forever" and they have!
