Torque converter anti-balloon plate question? #2575280
11/07/18 12:51 PM
11/07/18 12:51 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
At what point are anti-balloon plate needed?
Re: Torque converter anti-balloon plate question? [Re: 451Mopar] #2575341
11/07/18 02:56 PM
11/07/18 02:56 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
balloon plates are left over from the days that you had to modify a stock convertor core to build a racing converter. Majority of converters today are built from billet components and they are strong enough that balloon plates are not needed.
Re: Torque converter anti-balloon plate question? [Re: 451Mopar] #2575518
11/07/18 08:27 PM
11/07/18 08:27 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Anti ballooning plates are/were result of the invention of the Trans brake
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Torque converter anti-balloon plate question? [Re: 451Mopar] #2575845
11/08/18 01:24 PM
11/08/18 01:24 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
So, about 600 HP 505" stroker in a 4,000+ lb car with 3.23:1 gears.
I worry a stock high stall converter will balloon.
Which aftermarket converters would be safe from ballooning that don't have the plates?
Re: Torque converter anti-balloon plate question? [Re: 451Mopar] #2575865
11/08/18 02:07 PM
11/08/18 02:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Really seems like a question for whichever converter company you decide to go with, and what configuration they intend to build for you.
Re: Torque converter anti-balloon plate question? [Re: 451Mopar] #2576941
11/10/18 11:02 PM
11/10/18 11:02 PM
Byron, NY
Byron, NY
Why not just make sure there is an Anti ballooning plate on whatever converter you are buying...problem solved.
'60 Willys CJ5
Re: Torque converter anti-balloon plate question? [Re: 451Mopar] #2576961
11/11/18 12:21 AM
11/11/18 12:21 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
With a short gear like that - that plate would be advisable. Check with your converter supplier.
Re: Torque converter anti-balloon plate question? [Re: 451Mopar] #2577076
11/11/18 01:03 PM
11/11/18 01:03 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
My old converter was a Dynamic 10" race converter with the single anti-balloon plate, and my current converter is an Ultimate 9" with dual anti-balloon plates.
I used these converters several years ago.
I'll call Lenny at ultimate and ask what he suggests, but I think he will recommend the anti-ballooning plate?
