Need some Part information on Holley 4367 Carb #2572962
11/02/18 11:52 AM
11/02/18 11:52 AM
VA
dragon slayer Offline OP
VA
Found a Holley List 4367 carb which is a 70 383 MT carb, but the secondary bowl is missing, the meter plate loose, and there is no throttle plate. Otherwise looks pretty complete. The box did have several Chrysler style holley throttle plates. Each with different features
Can't find many picture or information on the net. The Holley book I have seen doesn't cover this specific carb or call out part numbers for the throttle plate.
So does anyone have a list of what the part number for the throttle plate and secondary meter plate for this carb would be? Maybe some close up pictures of the carb to help identify correct throttle plate, meter plate. Thanks
Re: Need some Part information on Holley 4367 Carb [Re: dragon slayer] #2572977
11/02/18 12:18 PM
11/02/18 12:18 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Try these folks Holley Tech 270-782-2900
2011 Drag Pak Challenger
Re: Need some Part information on Holley 4367 Carb [Re: dragon slayer] #2573032
11/02/18 02:15 PM
11/02/18 02:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Last time Ineeded that kind of info, I think I found it looking around on Allstate Carbs's website. allcarbs.com
Re: Need some Part information on Holley 4367 Carb [Re: dragon slayer] #2574470
11/05/18 04:18 PM
11/05/18 04:18 PM
VA
VA
No joy. Even when you find spread sheets from Holley does not look like the 70/71 carbs are even listed.
If anyone has period correct data sheet, or has numbers off original carb, I would be grateful. Thanks.
Re: Need some Part information on Holley 4367 Carb [Re: dragon slayer] #2574685
11/06/18 01:31 AM
11/06/18 01:31 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
There's some good rebuilders and restorers out there.
Try Baldwin Carburetors. He posted in here a few times.
Failing that, see if anyone on racing fuel systems forum has one for parts.
Most of the info on the factory carbs will be limited to the factory service manual and tech bulletins. More so with the idle mix with adjustable air bleed and sealed fuel mix screws.
Shop manual I assume you have or can get.
Master Tech Series:
http://www.imperialclub.org/Repair/Lit/Master/index.htm
Service Manual Revisions, Updates, and other info.
http://www.hamtramck-historical.com/library.shtml
Re: Need some Part information on Holley 4367 Carb [Re: dragon slayer] #2574706
11/06/18 02:21 AM
11/06/18 02:21 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Primary throttle plate 9R-213
Secondary throttle plate 9R-199
Secondary metering plate 34R-6153-38
Re: Need some Part information on Holley 4367 Carb [Re: 62maxwgn] #2575245
11/07/18 11:47 AM
11/07/18 11:47 AM
VA
VA
Thank you. Did early holley documentation have a part number breakout? The stuff I have found in late 80s and up books does not list the OEM Mopar List# carbs.
Re: Need some Part information on Holley 4367 Carb [Re: dragon slayer] #2575278
11/07/18 12:48 PM
11/07/18 12:48 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Try and find one of these,it has everything you need to know.
Re: Need some Part information on Holley 4367 Carb [Re: 62maxwgn] #2575351
11/07/18 03:17 PM
11/07/18 03:17 PM
dogdays Offline
dogdays  Offline
Speedway Motors has them for $53.98.
They ain't cheap ($24.95) any more.
R.
Re: Need some Part information on Holley 4367 Carb [Re: dragon slayer] #2575384
11/07/18 03:59 PM
11/07/18 03:59 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
look for a throttleplate with shlightly larger secondaries in the box of stuff
Re: Need some Part information on Holley 4367 Carb [Re: dragon slayer] #2577096
11/11/18 01:55 PM
11/11/18 01:55 PM
VA
VA
Ok, finally got the carb disassembled and looked at the various parts.
The secondary meter plate was 34R-6153B #38
The primary meter block had a 34R-6105B with number 6361 stamped on top. Not sure this is correct??
The throttle plate that looked most similar to period carbs (throttle shaft and vacuum tubes) is 12R-4298B Secondary are 1 3/4"
But the primary blades look like #109 no bleed hole, and the secondary had no numbers. Just aluminum blade.
Was the casting number on the throttle plate the part number for the whole assembly? Carb had previous work from what I can see, so not sure if primary meter block is original nor do I know if the throttle plate I have goes with it.
Re: Need some Part information on Holley 4367 Carb [Re: dragon slayer] #2577188
11/11/18 05:55 PM
11/11/18 05:55 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The secondary metering plate is correct.There are two 4367 carbs listed.R4367-1A-1AAS and R4367-2AAS,both primary metering blocks have different number,1AAS is 34R-6083A,2AAS is 34R-7204A.The throttle/body plate listed is 12R-4428A for both.
