1974 D100 Fuel level sending unit/pickup #2575241
11/07/18 11:41 AM
11/07/18 11:41 AM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
My old 74 long bed stepside fuel gauge reading has gone from erratic to non existent, I've checked all the connections so it now looks like it's time to drop the tank and pull the sump (all original). In preparation for what I think I will find I've been looking for a replacement and don't like what I'm seeing...none...Dodge Connection list one for a 77-80...anyone know if it will work or is adaptable?
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: 1974 D100 Fuel level sending unit/pickup [Re: RapidusMaximus] #2575708
11/08/18 03:01 AM
11/08/18 03:01 AM
Guitar Jones Offline
My 74 has the in cab tank. Where is yours?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 1974 D100 Fuel level sending unit/pickup [Re: Guitar Jones] #2575749
11/08/18 09:03 AM
11/08/18 09:03 AM
Weatherford, Texas
Weatherford, Texas
It is under the bed between the frame rail and the driveshaft, extends from just behind the front wall of the bed almost to the rear end.
1968 Plymouth GTX
Re: 1974 D100 Fuel level sending unit/pickup [Re: RapidusMaximus] #2575791
11/08/18 11:41 AM
11/08/18 11:41 AM
Weatherford, Texas
Weatherford, Texas
My son prior to taking the truck to prom a few years ago...his dog photo bombed him at the last second. Notice fuel filler neck location.
1968 Plymouth GTX
Re: 1974 D100 Fuel level sending unit/pickup [Re: RapidusMaximus] #2576026
11/08/18 07:33 PM
11/08/18 07:33 PM
Weatherford, Texas
Weatherford, Texas
Emailed Dodge Connection, they said the one they list won't work, I'm pulling the tank this weekend to inspect...never tried restoring/repairing one...is it even possible?
1968 Plymouth GTX
Re: 1974 D100 Fuel level sending unit/pickup [Re: RapidusMaximus] #2576053
11/08/18 08:56 PM
11/08/18 08:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes they can be redone if they haven't rusted away. Bad float can be replaced with a ford float.
Re: 1974 D100 Fuel level sending unit/pickup [Re: RapidusMaximus] #2576304
11/09/18 01:08 PM
11/09/18 01:08 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'm working on I think a similar tank, 73 d200. I found the sending unit to be bad (same high resistance at any position) so I'm planning to put an aftermarket (Dorman) sending unit somewhere nearby the original unit and retain the original unit for the sump. I'll be using an aftermarket fuel gauge where I can configure the ohm ranges, so I'm not worried about having a 73-10 sending unit.
But I thought if I was, I could probably get a different Dodge truck sending unit around 12" deep and try to cobble it together.
Re: 1974 D100 Fuel level sending unit/pickup [Re: Exit1965] #2576728
11/10/18 12:04 PM
11/10/18 12:04 PM
Weatherford, Texas
Weatherford, Texas
That's kinda where my head's at right now, gotta figure something out, my son wants to take it back to Savannah with him after Christmas leave and I don't want him attempting that with no gas gauge.
1968 Plymouth GTX
Re: 1974 D100 Fuel level sending unit/pickup [Re: RapidusMaximus] #2576798
11/10/18 03:18 PM
11/10/18 03:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you don't get it fixed leave a 5 gallon can of gas in the bed.
Re: 1974 D100 Fuel level sending unit/pickup [Re: RapidusMaximus] #2578463
11/14/18 05:51 PM
11/14/18 05:51 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Check out Vansauto.com they sell reproduction stainless steel fuel pickup sending units for the side mount tanks, also the Ramcharger/Trailduster tanks.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
