Eldebrock RPM valve keepers. #2575072
11/06/18 10:19 PM
11/06/18 10:19 PM
Canton, Ohio
Sport440 Offline OP
Sport440  Offline OP
Canton, Ohio
Could use some help, does anybody have any spare keepers for the BB eldebrock RPM heads? Was changing some springs and one went flying. Look at Summits site and you have to buy the whole pack, cant get just one. So it may end up being a $55 mistake, thought I would check here first before I pulled the trigger on a Full set. Thanks, Mike
Re: Eldebrock RPM valve keepers. [Re: Sport440] #2575141
11/07/18 12:52 AM
11/07/18 12:52 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
ive got some ive used on my rpms---not sure if they are "edelbrock" brand..in fact some are green....whoever makes those. I can send one
Re: Eldebrock RPM valve keepers. [Re: Sport440] #2575207
11/07/18 08:11 AM
11/07/18 08:11 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
The earlier Eddy locks used to be the 'machined' type but I note that all the ones I have seen lately are the budget pressed junk, you may be better off putting a full set of machined locks into it, for safety reasons.
Re: Eldebrock RPM valve keepers. [Re: Sport440] #2575300
11/07/18 01:36 PM
11/07/18 01:36 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
BB rpm and e street heads still use machined locks.
Just put a set together recently.
The “issue”’with 7 deg machined locks is...... seems like every brand has a slightly different installed height.
I can tell you for certain that Crane(not sure about the latest incarnation), Comp, Edelbrock, and the ones I get from my local engine parts warehouse are all slightly different, and provide slightly different installed height.
I don’t like to use “one” lock from another batch. If I lose one, I get another “pair” to install on one valve.
Re: Eldebrock RPM valve keepers. [Re: fast68plymouth] #2575499
11/07/18 07:50 PM
11/07/18 07:50 PM
Canton, Ohio
Sport440 Offline OP
Sport440  Offline OP
Canton, Ohio
I was definitely going to swap in a set of two. Thanks 493 for the offer. But I considered the idea of getting a used unknown life set of used keepers and reconsidered the idea.
I remembered I had $15 of Summit bucs hanging around and went and picked up a whole new set, im sure I may lose a few more in the future. Im set now, Thanks for the responses.
Re: Eldebrock RPM valve keepers. [Re: Sport440] #2575566
11/07/18 10:45 PM
11/07/18 10:45 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Now you can sell off your new extras in pairs for double the per piece price and guys would be happy to be able to get them and not have to buy a full set!
Re: Eldebrock RPM valve keepers. [Re: Sport440] #2575581
11/07/18 11:12 PM
11/07/18 11:12 PM
I think every engine assembler out there has as a few valve keepers take flight to be never found again whistling work I have had that happen more than once whiney shruggy
As far as replacing one keeper versus replacing both, its your choice work I have done that but I made sure the new single replacement was a identical twin (within .001 on retainer groove width, height and depth) to the one I was reusing scope up
