Need outdoor car cover recommendation #2574902
11/06/18 04:20 PM
11/06/18 04:20 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I need to free up some space in my garage to get some work done so I am going to have to store one of my cars on my covered patio for a couple of months. I would like to get an outdoor car cover though as rain and snow occasionally blow under the awning when it gets windy. I don't want to spend a lot of money on a high dollar cover though since this will just be a temporary situation and I won't likely have any use for the cover afterwards. Recommendations on a cover are appreciated.
Re: Need outdoor car cover recommendation [Re: 440mopar] #2574975
11/06/18 06:33 PM
11/06/18 06:33 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
You can probably put one of these up cheaper than a good outdoor cover, plus it won't be riding on the paint.
https://www.tractorsupply.com/tsc/produc...jAaAivnEALw_wcB
Re: Need outdoor car cover recommendation [Re: gzig5] #2574985
11/06/18 06:45 PM
11/06/18 06:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Those things suck and he already has a awning/patio to put it under.
A day like today with 30kts gusts will wreck that cheap cover in a hurry and damage your car.
Been there and done that at work. We tried one of those, a heavy duty commercial one. It wore out in 6 months and came apart numerous times and even after I bolted it together instead of pins. I used good concrete anchors to bolt it to concrete. The plastic bases that I anchored down cracked allowing the frame to move. The white material was blown to shreds in 6 months. Ours cost like 350 bucks, it was not a cheap one. It was made by shelter logic. Cool name.
I stored my car under a awning for 5 years or more, I have gone through numerous covers and California car covers are the way to go. Spend the big bucks the first time, it is cheaper and better for your car in the short run not to mention the long run.
Now I store that car in my airplane hangar. It is getting new California cover for inside the hangar.
Re: Need outdoor car cover recommendation [Re: Challenger 1] #2574992
11/06/18 07:00 PM
11/06/18 07:00 PM
Cincinnati, Ohio
Cincinnati, Ohio
My wife's GT mustang is under our back porch awning under a California Car Cover. It is the best cover I ever owned and is a deal compared to the 3 I bought before it for my cars.
This is our rear awning where my black challenger was parked. I have a scissors lift that I stored the car up on, it got it off the ground and offered more protection from the rain and snow. I always had a cover on it.
This what happens when you get drunk and forget to put the cover on the car.
And
forget to close the hood...LOL
It is running in this picture melting the snow off the engine^^^^^^^
Those cheap grey covers are just that, cheap. They fall apart rather quickly and leave lot's of dust all over your car. Almost best without one of those cheap grey covers. There are some better grey covers, the price will tell you the difference.
Re: Need outdoor car cover recommendation [Re: 440mopar] #2575012
11/06/18 07:52 PM
11/06/18 07:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
Originally Posted By 440mopar
I need to free up some space in my garage to get some work done so I am going to have to store one of my cars on my covered patio for a couple of months. Recommendations on a cover are appreciated.
I said this too, just for a few months to get some work done in my 2 car garage. I got some work done but my car stayed outside for years when it was only gonna be one winter. You can use the good outdoor cover inside after you bring the car back inside. All my cars are under cover inside. Protects against dings and chips.
Re: Need outdoor car cover recommendation [Re: 440mopar] #2575020
11/06/18 08:22 PM
11/06/18 08:22 PM
MA
steve70 Offline
steve70  Offline
MA
How about a disposable plastic cover over your regular cover to keep any rain/snow off the car.
https://www.ebay.com/itm/2-PACK-Clear-Pl...e/190817884902?
1970 Challenger T/A 4 speed
Re: Need outdoor car cover recommendation [Re: steve70] #2575116
11/06/18 11:43 PM
11/06/18 11:43 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
[quote=steve70]How about a disposable plastic cover over your regular cover to keep any rain/snow off the car.
I've done that with a project car and it worked fine.
What ever you do make sure the car cover is snug and won't slide around in the wind as it can rub thru the tops of fenders on cars with old or thin paint. You could always put some strips of the blue painters tape on the top edges to help protect it and then remove them later.
Re: Need outdoor car cover recommendation [Re: Neil] #2575433
11/07/18 04:52 PM
11/07/18 04:52 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Just bought a California car cover I will tell you how it works out . .
Re: Need outdoor car cover recommendation [Re: 440mopar] #2575478
11/07/18 07:03 PM
11/07/18 07:03 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a California car cover for the Charger, and it is a good cover. Had the Charger stored outside for over a year with the cover on it.
If storing where it is windy, mine did get blown partly off and rubbed the paint when I only used the center tie-down holes. A few extra straps or ropes around the trunk and hood should help keep the cover from rubbing and blowing around.
I also bought one of those 7-layer car covers off E-bay for the Jensen, and it is actually pretty nice, but I haven't used it outdoor for more than a few days.
Re: Need outdoor car cover recommendation [Re: 440mopar] #2575632
11/08/18 12:00 AM
11/08/18 12:00 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Can not answer what is the best car cover but I will be the first to say.
Best thing for your car is no cover. This is the best defense against moisture.
Re: Need outdoor car cover recommendation [Re: Magnum] #2575670
11/08/18 01:05 AM
11/08/18 01:05 AM
Cincinnati, Ohio
Cincinnati, Ohio
Very true...plastic would be a bad idea for long term storage. More than 3-4 daysat a time.
A good car cover breathes and beads water like magic, That red cover above in my pictures does both really well. The water runs off of it like it was plastic and it breaths really well. It fits so good I would be surprised to see it blown off. After 2 years of use the wife's GT is still flawless paint wise.
Re: Need outdoor car cover recommendation [Re: 440mopar] #2575676
11/08/18 01:23 AM
11/08/18 01:23 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Following as well. I'm not overly concerned about my paint, but I would like to keep some UV rays off of the interior as well. [Warlock and Dart]
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Need outdoor car cover recommendation [Re: 440mopar] #2575792
11/08/18 11:42 AM
11/08/18 11:42 AM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
For several Winters, we left one of my Fiancé’s cars out in the driveway for the Winter; no awning or anything. We put a cheap car cover on it and then covered it with two overlapping tarps that were attached with bungy cords under the car.
The car was a convertible and had a bad leak which is why we tarped it. We cleaned the car each Fall before doing this and in the Spring, when we uncovered it, the car looked as clean as the day we covered it up the previous Fall.
Just an option to think about.
Re: Need outdoor car cover recommendation [Re: parksr5] #2575879
11/08/18 02:31 PM
11/08/18 02:31 PM
moparx Offline
moparx  Offline
a couple of days ago, i saw an outdoor "bubble" cover deal by someone, whom i forgot almost as soon as i read the add. runaway it was [if i remember] in the new issue of either "street rodder" or "street scene" magazine. it made me think of this topic. i don't think i would like to try one of those in the winters around here.
beer
Re: Need outdoor car cover recommendation [Re: 440mopar] #2575930
11/08/18 03:48 PM
11/08/18 03:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a California Car Cover on my Road Runner for about 2 years now that I used to throw on my Charger for the winter in the garage for over 25 years. It has still held up well even outdoors. I don't really use it to protect the car. I mainly use it to hide it as an eye sore from the neighbors. (Yeah, it is that rough of a project car). I did notice the other day the cover was starting to turn a little green in a few spots, has moss or algae starting to grow on it from the tree above. It will probably need a good power washing once spring comes back around.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Need outdoor car cover recommendation [Re: 6PKRTSE] #2575964
11/08/18 05:21 PM
11/08/18 05:21 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I had a waterproof California Car Cover and after enough time in the rain water will go thru it. I ended up putting a tarp over the car cover to keep the water out.
Re: Need outdoor car cover recommendation [Re: 440mopar] #2576005
11/08/18 07:06 PM
11/08/18 07:06 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If it was under the awning I wouldn't put a cover on it. Every cover I have seen traps moisture to some extent. Yeah, a good breathable one would work, inside where there's little moisture to contend with. Outside, I would rather a little rain or snow get on it that can dry off and get some air flow.
Re: Need outdoor car cover recommendation [Re: gzig5] #2576118
11/08/18 11:34 PM
11/08/18 11:34 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Canopy frame and cover sold separately. shruggy
I have mechanical Aptitude.
I can screw up anything.
