Anyone tried this radiator? #2574290
11/05/18 10:21 AM
11/05/18 10:21 AM
Long Island New York
Mag162 Offline OP
Mag162  Offline OP
Re: Anyone tried this radiator? [Re: Mag162] #2574296
11/05/18 10:47 AM
11/05/18 10:47 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There is a whole big thread on cooling fans here on MoParts. Suffice it to say the setup in your link is less than optimal.
https://board.moparts.org/ubbthreads/ubbt...g-w-photos.html
Don't be the exception.
Re: Anyone tried this radiator? [Re: Mag162] #2574377
11/05/18 01:43 PM
11/05/18 01:43 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Looks like a good deal for the price? I have not used this radiator/setup but at least it is dual 1" tube radiator.
Re: Anyone tried this radiator? [Re: Mag162] #2574462
11/05/18 04:10 PM
11/05/18 04:10 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have that same radiator WITHOUT the fans, I have a 7 blade mechanical fan, keeps my 512ci 68 Charger with A/C in Southeast Texas heat 180ish all day long.
Re: Anyone tried this radiator? [Re: Mag162] #2574637
11/05/18 10:55 PM
11/05/18 10:55 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I was looking into one, without the fans and in a 22" core, but I found too many conflicting reports about them.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Anyone tried this radiator? [Re: Mag162] #2574723
11/06/18 04:03 AM
11/06/18 04:03 AM
Maryland
MoparMike1974 Offline
Maryland
I dont have the one with the fans but I have the 26" small block one. Hard to beat for the price. I liked it so much I bought a second one for a spare.
Re: Anyone tried this radiator? [Re: Mag162] #2575379
11/07/18 03:55 PM
11/07/18 03:55 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I have a 22" without fans.
Works great, was not a direct fit though.
The slots in the mounts for the lower bolts are about an inch too narrow.
It's not really hard to correct, but, it would take so little to make a top notch product.
Re: Anyone tried this radiator? [Re: Mag162] #2575513
11/07/18 08:10 PM
11/07/18 08:10 PM
Maryland
Maryland
I can comment on the mounting holes not lining up as well. Mine did not fit but I cant say if it was the radiators fault or not because the radiator supports were changed out to accept the 26" radiator.
