Rattle Between door skin and crash support, expanding foam? #2574215
11/05/18 01:16 AM
11/05/18 01:16 AM
Oklahoma
Mopar72Man Offline OP
Oklahoma
For the life of me, I cannot make any headway on this rattle i have. It's a high frequency one that is definitely between the door skin and door crash bar. I have fished things behind it, blown air around, tried to look in there...nothing.
I am considering low/no-bow expanding foam to calm down whatever is in there. Would that pose any inherent increase in rust creation?
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: Rattle Between door skin and crash support, expanding foam? [Re: Mopar72Man] #2574248
11/05/18 02:36 AM
11/05/18 02:36 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I'm sure it will to some point but if the rattle is driving you crazy just do it...Too bad you can't see what's going on.. I'm thinking something is lodged between them..I've seen where the crash bar somehow gets broken welds and does what you're describing also...Bottom line is the easy way out is foam it just don't go overboard... twocents
Re: Rattle Between door skin and crash support, expanding foam? [Re: screamindriver] #2574253
11/05/18 03:35 AM
11/05/18 03:35 AM
NY
LTLBEE Offline
LTLBEE  Offline
NY
Did you check that your door lock rods have the protective sleeves on them so they don't rattle when they touch.
Re: Rattle Between door skin and crash support, expanding foam? [Re: LTLBEE] #2574256
11/05/18 04:04 AM
11/05/18 04:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
This ^^
Most common cause of door rattles.
Re: Rattle Between door skin and crash support, expanding foam? [Re: autoxcuda] #2574293
11/05/18 10:30 AM
11/05/18 10:30 AM
Oklahoma
Oklahoma
This ^^
Yes, definitely not the lock rods.
Re: Rattle Between door skin and crash support, expanding foam? [Re: Mopar72Man] #2574320
11/05/18 12:14 PM
11/05/18 12:14 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I would use seam sealer before that foam. You know it's not going to cause rust and if the parts are close enough to rattle, the sealer will stabilize them.
Re: Rattle Between door skin and crash support, expanding foam? [Re: Mopar72Man] #2574330
11/05/18 12:30 PM
11/05/18 12:30 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Agree, seam sealer or that spray in lizard skin sound control. When I called 3m about this exact problem they said to use nvh 4274 between panels, it is sound deadener, vibration eliminator and is designed to go between panels and not print thru, or superglue it like fusor, also the best for between panels like your hood skin. 3m said other products may work, but nvh is designed for this. The question is can you get it where you need it with a caulk tube or not, if not look into lizard skin or other car stereo sound spray.
Re: Rattle Between door skin and crash support, expanding foam? [Re: 4406bbl] #2574419
11/05/18 02:55 PM
11/05/18 02:55 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
TURN UP THE RADIO! musik
JB Rhinehart, Realist
A-Body's RULE!
Re: Rattle Between door skin and crash support, expanding foam? [Re: Rhinodart] #2574777
11/06/18 12:20 PM
11/06/18 12:20 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
haha
open exhaust werks 2
I have mechanical Aptitude.
I can screw up anything.
Re: Rattle Between door skin and crash support, expanding foam? [Re: Mopar72Man] #2575220
11/07/18 10:36 AM
11/07/18 10:36 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Before using the seam sealer why not try stuffing something removable in that space(s?) - a piece of foam rubber, or just rubber, even paper or something just to diagnose and confirm where the rattle is coming from. If it isn't where you think it is you could go through a bunch of seam sealer and not fix it.
