Dana 60 - where to get?
#2574039
11/04/18 07:35 PM
11/04/18 07:35 PM
Posts: 4,525 Michigan
MarkZ
Worthy
Worthy
Looking for a Dana 60 housing and I don't know what vehicles I should look at. I'm not worried about it being machined for a snubber since the car will have Caltracks. Are there any differences I need to worry about with later housings from the 90's? Looks like a couple mid 90's Ford F-250 trucks in the local you-pick-it yard.
Thanks...
Re: Dana 60 - where to get?
[Re: MarkZ]
#2574118
11/04/18 10:57 PM
11/04/18 10:57 PM
Posts: 8,793 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I've seen a few D200 Dodge pickups for sale cheap with D60's under them.
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
[Re: MarkZ]
#2574139
11/04/18 11:13 PM
11/04/18 11:13 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
The best one I found was in a mid 60's Ford halfton and it had a power lock in it. I just had to change the sidegears to 35 and narrow it. I think 70's 3/4 ton pickups are the best source but they're getting harder to find in junkyards.
Sheldon
[Re: MarkZ]
#2574206
11/05/18 01:04 AM
11/05/18 01:04 AM
Posts: 43,719 Bend,OR USA
Cab_Burge
All Dana rear ends,27,30,44,60 series and so on are mark with the casting number of that housing on the passenger side bottom rear axle brace Dana 60 rear and front axles came with several different axle tube outside diameters, 2.5,3.0, 3 1/8, 3 1/4 and as large as 3 1/2 inch O.D. Look for a Dana 60 housing with the 3.0 O.D. axle tubes to use with stock 8 1/4, 8 3/4 and 9 1/4 inch Mopar car rear ends that had the same size U bolts to hold the rear end onto the leaf springs
[Re: MarkZ]
#2574461
11/05/18 04:08 PM
11/05/18 04:08 PM
MarkZ
Worthy
Worthy
I appreciate the input everyone. Reason I'm looking at the local pick yard is I can get housings for $100. There isn't anything wrong with my 8.75", so I can take my time looking for one. With this being a rust belt State anything older than 90's is extremely slim. I was unaware that 90's Fords no longer had Dana axles. I also didn't think about the axle tube diameter. Thanks again guys!
[Re: MarkZ]
#2582502
11/24/18 07:25 PM
11/24/18 07:25 PM
MarkZ
Worthy
Worthy
Just an update: I found a D60 that was pulled out of an 1983 F250 on Craigslist and got it for $150. Already dropped if off at the shop to start work. Thanks again guys!
[Re: MarkZ]
#2583471
11/27/18 12:00 AM
11/27/18 12:00 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Since the wrecking yard will only have 3/4 ton truck stuff. Have you considered a new S60. There are many advantages with this route.
[Re: MarkZ]
#2583547
11/27/18 02:53 AM
11/27/18 02:53 AM
Posts: 31,200 Oregon
AndyF
Just an update: I found a D60 that was pulled out of an 1983 F250 on Craigslist and got it for $150. Already dropped if off at the shop to start work. Thanks again guys! This is going in your 5th Ave? You might be the first guy to have a Dana 60 in a 5th Ave!
[Re: AndyF]
#2584850
11/29/18 08:45 PM
11/29/18 08:45 PM
MarkZ
Worthy
Worthy
Just an update: I found a D60 that was pulled out of an 1983 F250 on Craigslist and got it for $150. Already dropped if off at the shop to start work. Thanks again guys! This is going in your 5th Ave? You might be the first guy to have a Dana 60 in a 5th Ave! Heh, maybe for a 5A, but not an M. There is guy on here with one in a Diplomat. I've been wanting to change axle ratios back to 3.5x and the D60 thread on here got me thinking about the porker of a car I have with Caltracks and drag radials. Figured better safe than sorry. I need to figure brakes out now. From what I've read since I'm having the housing shortened I should use Ford ends and Explorer disk brakes. I'll go yard hunting soon for caliper brackets. This forum has been an absolute wealth of knowledge.
[Re: JAMESDART]
#2584947
11/29/18 11:51 PM
11/29/18 11:51 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would go with the ford ends and explorer brakes.You used to be able to buy complete explorer brake kits for reasonable price. that is what i did
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2608560
01/18/19 01:37 PM
01/18/19 01:37 PM
MarkZ
Worthy
Worthy
Just an update: got a housing from a 1983 F-250 off of Craigslist right before Christmas and had it rebuilt using parts from Doctor Diff. Power Loc, 3.54 and Ford Explorer discs. Can't wait to install it. Thanks again everyone.
