Female tube nuts for trans cooler lines- Hen’s Teeth! #2573832
11/04/18 12:36 PM
11/04/18 12:36 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Dang why is it so hard to find the nuts that go on the trans cooler lines before you flare them?!
All the brake and fuel lines I ever made were male line nuts. I ended up buying some male 1/8” npt to female 5/16” 45° flare fittings to replace the male/male fittings that have been in my transmission since the 70s.
The only ones I even found for sale were from inline tube and came on a ‘repair’ part- basically a stub with a bubble flare to act as a hosebarb.
Does anybody know where to get these female nuts? I struck out on amazon and mcmaster carr...
I’d kinda rather leave the stock nuts undisturbed in my trans case if possible.
Re: Female tube nuts for trans cooler lines- Hen’s Teeth! [Re: radar] #2573836
11/04/18 12:46 PM
11/04/18 12:46 PM
IMGTX Offline
IMGTX  Offline
My ace hardware sold them. They do not look stock but worked fine.
A quick google of Flare nut fittings will render both male and female but none of the female look like the stock "Square Back" fittings.
Re: Female tube nuts for trans cooler lines- Hen’s Teeth! [Re: radar] #2573842
11/04/18 01:00 PM
11/04/18 01:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Home Depot & Lowes both sell flare nuts in the plumbing sections.
Re: Female tube nuts for trans cooler lines- Hen’s Teeth! [Re: radar] #2573858
11/04/18 01:28 PM
11/04/18 01:28 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
68 Charger R/T 440 auto
Re: Female tube nuts for trans cooler lines- Hen’s Teeth! [Re: radar] #2573962
11/04/18 05:06 PM
11/04/18 05:06 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Cool! Thanks
