Compression and Octane #2573134
11/02/18 06:06 PM
11/02/18 06:06 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Dumb question but I am putting together a 2004 5.7L with stock heads and I want to know what is the highest Compression I can go and still maintain using 93/94 octane gas. I want to stay away from the 110 octane due to it being $7.99 per gallon.
help and I am grateful for all answers. I am back to learning all over again.
Thank you
Kiddart
Re: Compression and Octane [Re: Kiddart] #2573191
11/02/18 08:14 PM
11/02/18 08:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Plastic intake still?
If yes then at least 11 to 1. The 6.4 is about there with 205 thermostat and a lean emissions friendly mix and you know they put a little room to spare in it. Probably be silly to go under 11.5, these things are very octane tolerant.
Aluminum intakes heat the air a bunch and will probably take 1 to 1/2 point less compression.
Re: Compression and Octane [Re: Kiddart] #2573357
11/03/18 10:38 AM
11/03/18 10:38 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Hi hotrod,
I will be using the new Prefix Cascar intake. So I feel 10.1 or 11.1 I can still run premium gas? that would be awesome. it does have the stock chamber head. I will plan on getting the compression up.
anyone else like to weigh in?
Thank you
Kiddart
Re: Compression and Octane [Re: Kiddart] #2573486
11/03/18 03:23 PM
11/03/18 03:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
On my engine build I would shoot for 11 to 1 then or maybe a hair less but not more. I would focus on things like a tight quench and getting as cool air to it as possible and with an ignition curve made for the modern hemi motor instead of a 1950s design wedge it should be fine.
Re: Compression and Octane [Re: HotRodDave] #2579861
11/18/18 03:06 PM
11/18/18 03:06 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
12:1....And maybe a little more 12.4:1 or so. Tune up has to be right on though. Hemi's can tolerate a lot more compression than other engines. And with twin plugs per cylinder, the G3 is the best.
If I find a block for my heads, I am going 13:1 with the thinnest head gaskets I can get and go from there.
Re: Compression and Octane [Re: Kiddart] #2579899
11/18/18 05:57 PM
11/18/18 05:57 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
I've been running 12:1 and 93 octane forever with no issues. Plenty of street and track miles.
Re: Compression and Octane [Re: Kiddart] #2579962
11/18/18 08:50 PM
11/18/18 08:50 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Lots of people put the eagle heads on the earlier engines and that puts them around 12 to 1. If using a stock ecu, just need a tune.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Compression and Octane [Re: Kiddart] #2580107
11/19/18 09:04 AM
11/19/18 09:04 AM
Australia
aus370 Offline
aus370  Offline
Australia
Cam selection has influence on what your dynamic compression ratio ends up at : that's what a smart guy told me ; anyway It's worth looking into.
Re: Compression and Octane [Re: Kiddart] #2580110
11/19/18 09:48 AM
11/19/18 09:48 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
FWIW, the 428 in my 2014 Ram is 12.6 to 1 static with the Eagle head and I run a comp cams"270"
Duration @ .050" Intake: 222
Duration @ .050" Exhaust: 230
Valve Lift Intake: 0.615
Valve Lift Exhaust: 0.609
Lobe Sep. Angle: 115
93oct......A good tune is a must ,
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Compression and Octane [Re: Kiddart] #2580133
11/19/18 11:41 AM
11/19/18 11:41 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
this is lots of good info here. right now I have no issue filling up with 93 octane. the price of that sure beats race fuel. I really don't want to go over 11 to 1 right now because I may boost later. at that point I will change the slugs(pistons) and get right back to 9 to 1 and use some boost. that's way down the road. for now I want miles on this car to pay for the investment.
Thank you
Kiddart
Re: Compression and Octane [Re: Kiddart] #2598265
12/29/18 07:22 AM
12/29/18 07:22 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I think about this alot and with the low spark lead on timming i am wondering if its possible to run well into the 13s with some tight lobes
Re: Compression and Octane [Re: sixpackgut] #2598315
12/29/18 12:02 PM
12/29/18 12:02 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I think it's possible.
