Master cyl. question #2573484
11/03/18 03:20 PM
11/03/18 03:20 PM
Ohio
fiddlestix Offline OP
Ohio
I have a 2 bolt aluminum master cylinder I bought from
Rick Eherenberg many years ago I'm going to use. It has a 9/16" thread in the front port and 1/2" threads in the rear port. Which reservoir is front brakes and which is rear. I don't see much difference in reservoir size. Thank you for the help.
Re: Master cyl. question [Re: fiddlestix] #2573494
11/03/18 03:40 PM
11/03/18 03:40 PM
AndyF Offline
AndyF  Offline
Front is rear and rear is front.
Re: Master cyl. question [Re: fiddlestix] #2573514
11/03/18 05:10 PM
11/03/18 05:10 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Depends. Typically, the rear port (towards the pushrod) is the higher volume port. On a big rear tire car with big rear brakes and skinny fronts, you want the rears to do more work and would plumb the rears to the rear port. On a street car where the front brakes do 80% of the work, You want the fronts to get the higher volume.
