Compression and Octane
#2573134
11/02/18 06:06 PM
11/02/18 06:06 PM
Posts: 1,552 Michigan
Kiddart
Dumb question but I am putting together a 2004 5.7L with stock heads and I want to know what is the highest Compression I can go and still maintain using 93/94 octane gas. I want to stay away from the 110 octane due to it being $7.99 per gallon.
help and I am grateful for all answers. I am back to learning all over again.
Thank you Kiddart
Re: Compression and Octane
[Re: Kiddart]
#2573191
11/02/18 08:14 PM
11/02/18 08:14 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Plastic intake still?
If yes then at least 11 to 1. The 6.4 is about there with 205 thermostat and a lean emissions friendly mix and you know they put a little room to spare in it. Probably be silly to go under 11.5, these things are very octane tolerant.
Aluminum intakes heat the air a bunch and will probably take 1 to 1/2 point less compression.
[Re: Kiddart]
#2573357
11/03/18 10:38 AM
11/03/18 10:38 AM
Kiddart
Hi hotrod,
I will be using the new Prefix Cascar intake. So I feel 10.1 or 11.1 I can still run premium gas? that would be awesome. it does have the stock chamber head. I will plan on getting the compression up.
anyone else like to weigh in?
Thank you Kiddart
[Re: Kiddart]
#2573486
11/03/18 03:23 PM
11/03/18 03:23 PM
HotRodDave
Kalispell Mt.
On my engine build I would shoot for 11 to 1 then or maybe a hair less but not more. I would focus on things like a tight quench and getting as cool air to it as possible and with an ignition curve made for the modern hemi motor instead of a 1950s design wedge it should be fine.
[Re: HotRodDave]
#2579861
11/18/18 03:06 PM
11/18/18 03:06 PM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
12:1....And maybe a little more 12.4:1 or so. Tune up has to be right on though. Hemi's can tolerate a lot more compression than other engines. And with twin plugs per cylinder, the G3 is the best.
If I find a block for my heads, I am going 13:1 with the thinnest head gaskets I can get and go from there.
[Re: Kiddart]
#2579962
11/18/18 08:50 PM
11/18/18 08:50 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Lots of people put the eagle heads on the earlier engines and that puts them around 12 to 1. If using a stock ecu, just need a tune.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Kiddart]
#2580107
11/19/18 09:04 AM
11/19/18 09:04 AM
Posts: 80 Australia
aus370
Australia
Cam selection has influence on what your dynamic compression ratio ends up at : that's what a smart guy told me ; anyway It's worth looking into.
[Re: Kiddart]
#2580110
11/19/18 09:48 AM
11/19/18 09:48 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
FWIW, the 428 in my 2014 Ram is 12.6 to 1 static with the Eagle head and I run a comp cams"270" Duration @ .050" Intake: 222 Duration @ .050" Exhaust: 230 Valve Lift Intake: 0.615 Valve Lift Exhaust: 0.609 Lobe Sep. Angle: 115
93oct......A good tune is a must ,
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: Kiddart]
#2580133
11/19/18 11:41 AM
11/19/18 11:41 AM
Kiddart
this is lots of good info here. right now I have no issue filling up with 93 octane. the price of that sure beats race fuel. I really don't want to go over 11 to 1 right now because I may boost later. at that point I will change the slugs(pistons) and get right back to 9 to 1 and use some boost. that's way down the road. for now I want miles on this car to pay for the investment.
Thank you Kiddart
[Re: Kiddart]
#2598265
12/29/18 07:22 AM
12/29/18 07:22 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I think about this alot and with the low spark lead on timming i am wondering if its possible to run well into the 13s with some tight lobes
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2598315
12/29/18 12:02 PM
12/29/18 12:02 PM
ric3xrt
Trumbauersville PA
I think about this alot and with the low spark lead on timming i am wondering if its possible to run well into the 13s with some tight lobes I think it's possible.
