Chrome ignition control module #2572102
10/31/18 01:24 PM
10/31/18 01:24 PM
Spring Texas
julius2 Offline OP
julius2  Offline OP
Spring Texas
What are we going to replace P4120534 with now that its dis-continued
Re: Chrome ignition control module [Re: julius2] #2572119
10/31/18 02:02 PM
10/31/18 02:02 PM
WA
tman Offline
tman  Offline
WA
I like the Rev N nator. My old Chrome box is my spare.
Re: Chrome ignition control module [Re: julius2] #2572154
10/31/18 02:50 PM
10/31/18 02:50 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I like my Rev N ator too, but that's an entire system and not cheap. I have that in my Diplomat with the stroked 360.
Maybe the HiRev 7500? I bought one for my Power Wagon but haven't installed yet. Sounds good from what I read.
https://www.ebay.com/itm/JEGS-40805-HiRev-7500-0174-Ignition-Control-Unit/401591552120?
Facts are stubborn things.
Re: Chrome ignition control module [Re: julius2] #2572164
10/31/18 03:03 PM
10/31/18 03:03 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
^ Internet picture.
R. Ehrenberg is a seller on ebay also if you would rather buy from him up
Re: Chrome ignition control module [Re: julius2] #2572328
10/31/18 07:41 PM
10/31/18 07:41 PM
WA
tman Offline
tman  Offline
WA
That blue one looks reasonable for the money. Its all in the budget. Ehrenbergs price looks ok with free shpg.
https://www.ebay.com/itm/MOPAR-Hi-Po-ECU-Electronic-Ignition-Control-Box-B-Body-Charger-Satellite-GTX/323502461213?hash=item4b523fd11d:g:f7EAAOSwi0RXzdQB
Re: Chrome ignition control module [Re: julius2] #2572349
10/31/18 08:50 PM
10/31/18 08:50 PM
I'd suggest a parts house or eBay 4 pinner (& a spare in the glove box).
Re: Chrome ignition control module [Re: tman] #2572362
10/31/18 09:22 PM
10/31/18 09:22 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
https://www.ebay.com/itm/MOPAR-Hi-Po-ECU...X/323502461213?
Re: Chrome ignition control module [Re: julius2] #2572584
11/01/18 02:14 PM
11/01/18 02:14 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
I've run a Hi Rev 7500 on my Challenger for a couple of years now (about 15K miles). The car runs fine and I've had no issues with it.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Chrome ignition control module [Re: julius2] #2572613
11/01/18 03:05 PM
11/01/18 03:05 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Myself I've gone to GM HEI modules with the Ford TFI coil on the type of applications I used to use orange and chrome boxes on. Both the coil and the module together cost less than the Chrysler module alone, they wire right up to a Mopar distributor and produce a nice spark.
For the more performance oriented stuff, msd.
Rich H.
Esse Quam Videri
Re: Chrome ignition control module [Re: julius2] #2572714
11/01/18 07:08 PM
11/01/18 07:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure where you are pricing your stuff
Chrysler ICU - $13.88
GM ICU - $9.54
Ford TFI Coil - $8.66
Cheapest regular priced options at RA. Pretty sure I wouldn't use those options in any case, but the point it it's not really cheaper.
You price the high end and the GM/Ford combo is about twice the Mopar ICU cost.
Don't be the exception.
Re: Chrome ignition control module [Re: julius2] #2572788
11/01/18 10:24 PM
11/01/18 10:24 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Wells GM 4 pin module hidden in a 70s box gets it done lol
Re: Chrome ignition control module [Re: julius2] #2572942
11/02/18 11:04 AM
11/02/18 11:04 AM
S.E. Michigan
S.E. Michigan
If I remember correctly, p4120534 was priced in the (ballpark) 80 range.
I'm quite familiar with these items as I ran them for decades and worked for the manufacturer who used to sell them.
For me, time for something different. For others maybe not.
Rich H.
Esse Quam Videri
Re: Chrome ignition control module [Re: julius2] #2573180
11/02/18 07:42 PM
11/02/18 07:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ok, didn't realize you were talking about buying MP stuff. Standard LX101 is under $40. Off brand equivalent is under $14, not sure I'd use that though or rhw later MP stuff for that matter.
Re: Chrome ignition control module [Re: julius2] #2573188
11/02/18 08:09 PM
11/02/18 08:09 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the LX101 is a reasonable alternative but I don't consider it to be an absolute replacement for the chrome. I think the chrome is a better performance box. I use an FBO with the rev-limiter on one of my cars and like it, but it's a couple hundred bucks for the kit. my other car uses the LX101 without any issues.
Re: Chrome ignition control module [Re: julius2] #2573271
11/02/18 11:28 PM
11/02/18 11:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I doubt most of the people running a chrome box actually need a chrome box. 7500rpm is a lot.
Re: Chrome ignition control module [Re: Supercuda] #2573317
11/03/18 03:08 AM
11/03/18 03:08 AM
I'd suggest going to a yard & getting (2) OE 4 pin ECU's. OR (2) from a parts house (most are overseas made now), even the standard motor products LX101 (I believe). A high(er) dollar one might give more power but I ain't convinced but I cant say for sure. I like the HEI mounted under the dist on an alum plate (easy to make) or www.designed2drive.com has a nice alum tailor made one but it is pricey (dont forget the heat sink paste between it & the alum plate) & its a full 12V system so get an E coil or some full 12V coil. Dogdays had me get the furd TPI coil mentioned (yes dirt cheap from RA) & I put it on a DD truck with an OE HEI module & it was a new buildup then was sold quick all of a sudden so no actual before/actual exp but nothing jumped out at me about it but that setup is coming back to me in a trade so I will be trying it on something current. As I'm typing this I now remember that it did start instantly every time.
Re: Chrome ignition control module [Re: Supercuda] #2573603
11/03/18 09:15 PM
11/03/18 09:15 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Right now, Rock Auto has a clearance sale on the Standard Motor Parts unit...$6.98 each.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Chrome ignition control module [Re: Kowal] #2573698
11/04/18 12:55 AM
11/04/18 12:55 AM
^^^ (3) of em are $28.93 to my door. the LX101's are made in china now but I'd feel OK with 2 spares. All that is left is if they "pull" timing like some of the newer MP orange boxes reportedly do. All it is supposed to do (& nothing more) electronically is open the coil primary to collapse it when the dist pickup triggers it to do so & any electronic "delay" in that function pulls timing.
Re: Chrome ignition control module [Re: RapidRobert] #2574481
11/05/18 04:55 PM
11/05/18 04:55 PM
dogdays Offline
dogdays  Offline
IMHO the reason any box "pulls" timing is that the engine speed is catching up with the transistor's speed. If you look at transistor catalogs you can see some interesting things.
R.
