Replacement Valve Guide Sizes? #2572315
10/31/18 06:56 PM
10/31/18 06:56 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Small block 340 with X-heads. My machine shop is having a problem finding replacement valve guides in an over-size to press into the head. The heads had bronze guides and some of them were moving due to previous incorrect machine work. I am looking for a guide that I can have pressed into the heads in an over-size. Does this part exist? If so where to find it? Any other solutions? My machine shop is not Mopar-centric...
Some people you just can't reach...
Re: Replacement Valve Guide Sizes? [Re: Suregrip] #2572428
10/31/18 11:45 PM
10/31/18 11:45 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
what size do you need ?
what size are the holes now ?
Re: Replacement Valve Guide Sizes? [Re: Suregrip] #2572488
11/01/18 02:11 AM
11/01/18 02:11 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
I have run across where sometimes the bronze guides will actually shrink either from heat cycles or overheated or the quality of the bronze material isn't very good and they will start to slip or move around, not necessarily because of improper machining.
Like what was said before what size is the guide bore? Generally the guide bore is .500 id and the guide od is .502 and if the guide bore is bigger you should be able to find guides that are bigger in od and the guides might have to be polished down to get the proper press fit.
A very good quality bronze guide to use would be C.H.E they can make exactly what you need or you can usually find a guide thats close and make it fit your application. Here is the link for them below.
.https://www.cheprecision.com/html/guides.html
Re: Replacement Valve Guide Sizes? [Re: Suregrip] #2572545
11/01/18 12:05 PM
11/01/18 12:05 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
It's essentially a brass/bronze tube right? They should be able to chuck them up on an arbor in a lathe and knurl the outside for part of the length. This will increase the effective diameter and should allow them to be pressed in and hold without any adhesive. May have to play with the depth on one or two to get it right. Might save the cost of custom parts and shouldn't be expensive to do. Should probably be honed internally to correct size because the knurling operation will probably close the hole up a little.
Re: Replacement Valve Guide Sizes? [Re: Suregrip] #2572552
11/01/18 12:24 PM
11/01/18 12:24 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
I am looking for an valve guide in 0.372 inside diameter to machine for a 0.375 valve stem, the outside diameter needs to be slightly over the stock .500 size. Machine shop says .503 to .505?
Re: Replacement Valve Guide Sizes? [Re: Suregrip] #2572660
11/01/18 05:03 PM
11/01/18 05:03 PM
Sullivan, IN
Mopar Sam Offline
Mopar Sam  Offline
Sullivan, IN
A couple of years ago I needed some .507 od guides and found them through PEP Precision Engine Parts. Go to their site, click on " downloads " then download the PEP catalog by size. They list .372 id x .504 and .507 od guides.
Re: Replacement Valve Guide Sizes? [Re: Mopar Sam] #2574483
11/05/18 05:08 PM
11/05/18 05:08 PM
dogdays Offline
dogdays  Offline
It sounds like the guides are already out. Too bad, otherwise the shop could have left the guides in there and installed sleeves.
Check out Goodson.
R.
Re: Replacement Valve Guide Sizes? [Re: Suregrip] #2574497
11/05/18 05:34 PM
11/05/18 05:34 PM
Washington
madscientist Offline
Washington
I've seen .530 OD guides. But you also need the reamer.
I can say in almost 35 years I've never seen your issue.
Re: Replacement Valve Guide Sizes? [Re: Mopar Sam] #2574741
11/06/18 10:21 AM
11/06/18 10:21 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
I'm pretty sure PEP can make whatever you need.
NMCA NSS 67 Coronet
Re: Replacement Valve Guide Sizes? [Re: Suregrip] #2574823
11/06/18 01:22 PM
11/06/18 01:22 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You need a new machine shop.
Kevin
