Re: dialing in throttle pressure cable
[Re: maxwedge1]
#2572333
10/31/18 07:52 PM
10/31/18 07:52 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
As long as it kicks down at WOT you're OK.
Adjusting so that the trans lever is fully back at WOT as everybody suggests often produces your symptoms. With correctly adjusted factory linkage the lever is not full back at WOT.
[Re: maxwedge1]
#2572353
10/31/18 09:14 PM
10/31/18 09:14 PM
Posts: 6,224 JERSEY
RJS
JERSEY
have been gradually adjusting a bouchillion cable ,smallblock 727,b&m shift kit. i now have it when the carbs wot the trans lever is fully back. when in Drive i get firm 1-2 shift and it does kick down firm when mashing the pedal. but i do get kind of harsh down shifts when slowing to a stop. i have been gradually moving the cable, a 1/8" or so. the previous adjustment in Drive the 1-2 was soft and kick down seemed late and didnt really feel the downshifts . is my current adjustment ok? or should i back it off a bit. The downshift when slowing to a stop is because the lever isn't returning fully forward when you let off the gas, do you have the spring attached properly from the lever to the bellhousing that they provided? Also the whole adjustment according to their instructions is about a 1/4" total so I would go back to the instructions and make sure you have it setup as they say. I put one in a few weeks back and it was perfect at the install. Also the lever should go all the way back at full throttle less a very small amount so your not bottoming the lever all the way back. Ron
[Re: maxwedge1]
#2572390
10/31/18 10:30 PM
10/31/18 10:30 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Hopefully a return spring like rarefish said, is all you need.
or
The problem with the cable kits is they assume everyone has the same throttle lever on their transmission. You may need more reaction on the transmission end which would be a shorter lever.
Presently you are only making a linear adjustments. You can adjust it forward or backward and find it is always a compromise on the other end.
The solution is a ratio change. The lever needs to be longer or shorter. Short is easy because you can just drill a new hole inboard, closer to the pivot.
[Re: Magnum]
#2572411
10/31/18 11:16 PM
10/31/18 11:16 PM
Posts: 6,224 JERSEY
RJS
JERSEY
or
The solution is a ratio change. The lever needs to be longer or shorter. Short is easy because you can just drill a new hole inboard, closer to the pivot. Bouchillon set up gives you the proper lever also. Their kit is really plug and play. Ron
